Looking for full range sound!!
Back at it with the TL SH
Hey guys,
Ok so i am looking to get a full signal from the HU. So i am trying to figure out which is a full range speaker.
I have a TL-S 2007.
The question is....Which are full range speakers, the fronts or the rear deck ones?
I think its the rear deck speakers that are full range but i am not too sure.
Does anyone know for sure?
I have a TL-S 2007.
The mid-woofs that are in your doors are the same speakers as are in the rear deck. The HU counts on the natural roll-off of the speakers for the crossover and the fronts have the tweeters wired in parallel with them to provide the high end (the tweeters have a capacitor to block the low freqs).
True. Think of the front stage as components with a ghetto crossover. The speakers in the rear, I don't know what frequency they roll off at but I'm sure its not the 20k that real full range speakers do.
If you search back to around '04 or '05 there's a thread where it shows the factory equalization on each channel, what's full range, the sub crossover freq, the center crossover, the entire wiring diagram, basically everything you would ever need to install any system in a TL.
I believe it was by "Death to Toasters" but I may be wrong.
FWIW, I'm pretty sure both the fronts and rears are full freq but I *think* the fronts have a lot more eq going on. I've run the rear channel to my fronts and there seems to be a lot more highs going on but if you can find that thread it will clear everything up.
Everything is stock just that i wanted to take the signal from my HU and totally by-pass the amp. But that failed since the signal is too weak.
Is there anything i can use to make the signal comming from the HU louder?
Sep 17, 2015 09:01 PM
