Location of 12V accessory wire...
Old May 14, 2006 | 01:38 PM
Revolutions's Avatar
8AT > 6MT
I read some of the other forums regarding hooking up amps etc. What i'm doing is hooking up just an amp for my sub and my amp requires a remote turn on signal to turn on the amp.
On my previous hondas, i always hooked up the remote wire to the RED wire, which is the 12v accessory wire...which i'm sure is no different than an acura. I'm wondering where this wire is? will it be located behind the dash or can i find it under the passenger kick panel where the stockie amp is? i looked but i didn't see any SOLID red wires only...i read a post about hooking it up to the fuse box etc under the driver side but i haven't taken a look yet...just trying to avoid the fusebox...
thanks in advanced for any input you may have.
Old May 14, 2006 | 01:43 PM
axiom's Avatar
If you have navi, the yellow and red wire going to the navi unit in the trunk will work fine.
Old May 14, 2006 | 01:48 PM
8AT > 6MT
sorry, forgot...no navi
Old May 14, 2006 | 02:28 PM
Crook's Avatar
Fuse 32 on driver's kick panel. Tap into the lower blade of the fuse so your wire will be protected by the fuse. You can also use minifuse "add-a-circuit" which was available from autozone. The blue remote wire runs to my trunk where it turns on my sub amp, Dom's TVandNav and a reverse camera.
Old May 14, 2006 | 02:34 PM
8AT > 6MT
what about fuse #29? i read people use that one too...i'm just trying to find the best way =) and easiest =)
Old May 14, 2006 | 02:57 PM
Crook's Avatar
Sorry, I have no idea what fuse 29 is used for.
I used 32 because it is the remote turn on signal to power up the radio, AC, Nav and Handsfree when the key is turned to ACC 1.
Old Sep 24, 2007 | 10:04 AM
7Davie7's Avatar
i would HIGHLY recoomened using one of these for tapping in a fuse. Made hooking up the remote turn-on wire for my Basslink a total breeze, works prefectly.
http://www.partsexpress.com/pe/showd...number=071-585
You can get these at local AutoZone's....worth it's weight in Gold!
Old Sep 24, 2007 | 10:07 AM
7Davie7's Avatar
just saw that this link doesn't work for some reason? just do a search for "add a circuit" or type in part number 071-585 that will work!
Old Sep 24, 2007 | 01:01 PM
BAD DNKY's Avatar
i tapped mine on the very first (7.5 )fuse on the top and it works great!
Old Dec 28, 2015 | 11:27 AM
Ben Benson's Avatar
3rd Gear
Acura TL Accessory wire in trunk
This worked out perfectly. Thanks a lot.
#TL 2006, Navtool 3.0
Accessory wire. Red and yellow coated.
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
Euro4gen
Dec 12, 2015 03:14 AM
AJRozsa
Oct 5, 2015 07:50 PM
