LOC vs Audio Interface integration Methods
Old Aug 22, 2009 | 09:13 PM
mc_holla's Avatar
I am somewhat stuck between two methods available for adding a aftermarket amp (in addition to the factory one) to my system. The options are as follows:
Option #1: Line Out Converter (ie PAC Trucklock). This device is relatively cheap ($25) and is spliced into the rear speaker wires to create an RCA input/output. Sound quality is said to be affected due to the fact that this device converts a amp'd signal into a RCA acceptable signal.
http://www.pac-audio.com/productDeta...&CategoryID=28
Option #2: Deck integration interface (ie PAC AOEM-HON20). This device connects to the radio unit in-between the unit and the plug/harness that goes out to the amp (Plug-n-play). Pre-amp'd RCA outputs then are made available for front and rear signals outputs (4ch). I like this method the most because of the true, unconverted signal it produces but of course it requires more work due to the fact that you have to access the rear of the radio deck.
Please tell me what you think.
Mc HoLLa
2004 NBP TL 6sp w/ Navi
Old Aug 23, 2009 | 01:33 PM
xxx_busa's Avatar
You can always go this method
https://acurazine.com/forums/car-parts-sale-361/audio-control-lc-6i-perfect-use-acura-head-units-740521/
Old Aug 24, 2009 | 12:04 AM
dirtywop's Avatar
chris
I got a (clean sweep) from JL audio.. takes the stock signal cleans it up. and gives you outputs for your amps to run mids n highs n your subs....its on JL's, site..
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
