LOC Questions
Old Apr 30, 2007 | 07:35 PM
mrbrace's Avatar
LOC Questions
Ok I did do a search for LOCs and found some good information. However, I am unable still to have this questions answered.
I plan on hooking up my speakers here in a couple months that was from my old TC. Its a killer system so I want to be prepared to put it in my TL and its going to take a while to get all the right parts.
Anyhow, on the LOCs what kind of Volts does it give out. Ya know that some headunits give out 5 Volts and some 8 Volts, etc. My alpine amps do not adjust by gain they adjust by how many volts are coming out from the 'head unit'. So I wanted to know if anyone knew how many Volts come out so I could properly set my amps.
Hope this makes sense.
Matthew
Old Apr 30, 2007 | 07:45 PM
ice2fire11's Avatar
line output converter
alot are adjustable. its not going to have the output power that a good head unit has. the other thing with the adjustable ones is that you can "turn up" distortion. they've got there pro's and con's. lemme know if you want me to go into more detail on them or anything car audio related.
Old Apr 30, 2007 | 07:49 PM
mrbrace's Avatar
yeah I was looking at getting the PAC Trunk-LOC with the line for remote turn on without having to find a switching power source. I am pretty sure I won't have much distortion but who knows.
Old Apr 30, 2007 | 11:06 PM
NocturnalTypeS's Avatar
Where do i get an amp turnon wire from if i use the loc??
Old May 1, 2007 | 01:50 AM
datmrman's Avatar
Taken from another thread:
Originally Posted by datmrman
Please search before posting.
Here are a few threads I've found with a keyword search for remote:
More with a search, but most post to fuse #32. The third link has pictures.
Old May 1, 2007 | 03:38 PM
Greengecko's Avatar
I don't think LOCs use a power source, so no turn-on lead is required. I'm using PAC LOCs and all you need to do is adjust the gain using a small flathead screwdriver. I don't know about voltage either -- I just based the right level on the amount of hiss coming out of my speakers. When that sounded good, that's where I left them. Is there a better way?
Old May 1, 2007 | 03:50 PM
iodprod's Avatar
use the stinger SLOC2 fixed output line out converter
i hooked it up to my sub wires in the back it works perfectly
no distortion at all
use the amp's gain level to whatever you want!
Old May 2, 2007 | 08:24 AM
mrbrace's Avatar
the thing is the alpine mrd-m605s only set the gain according to the input of the signal from the RCAs or the headunit at that. You are not able to adjust the gain on the fly (meaning that you have to set it to whatever the rcas are inputting)
Old May 3, 2007 | 10:37 AM
Greengecko's Avatar
Very good question. I have an Alpine MRD-M605 as well. But I still think it's the same as if it were the old-fashioned gain dial -- ideally it should match up voltage-wise, but since you don't have a readout on the LOCs, you just have to go by ear. Maybe the LOC package has info on voltage output....
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
