Light bulbs navi control help!!!
You have a few options.
Buy OEM bulbs - they all have different part numbers.
You can check for part number on oemacuraparts
Buy Radioshack 7219 bulbs - they're brighter than OEM
Buy LED bulbs T3 neo wedge.
If you're looking for blue, then T3 neo wedge LEDs is what you will need to buy.
I just installed the neo wedge leds as well. I went through a couple of different sellers on ebay because I am a stickler and the first two sets did not match exactly. The first set I got were blue, but they had an almost purplish tint. The second set were a lot closer to the instrument panel blue, but the bulbs were bigger and did not fit (depth wise) in all the different sockets. The last set finally matched exactly and look great. I wish I had taken pictures of the other two to show the difference.
This is the link to the bluish/purple leds. They still look good, but the color did not match.
http://www.ebay.com/itm/20Pcs-Ultra-Blue-LED-T3-Neo-Wedge-SMD-LED-Dash-Climate-Gauge-Light-Bulbs-8mm-US-/251626916099?hash=item3a96220903&vxp=mtr
This is the link to the closer blue, but the bulb part sticks out a lot.
http://www.ebay.com/itm/10pcs-T3-Neo-Wedge-Dash-LED-Bulbs-Blue-39397-SA5-003-35852-SEP-A02-/201315548055?hash=item2edf577b97&vxp=mtr
this is the link to the set that is an exact match to the instrument panel blue. If you notice, there are two leds instead of one like on the other two.
http://www.ebay.com/itm/10x-Blue-T3-Neo-Wedge-SMD-LED-Light-Instrument-Cluster-Panel-Lamps-Gauge-Bulbs-/121612115658?hash=item1c50a59eca&vxp=mtr
The leds do look really good and a lot better than the oem bulbs. Anyway, good luck.
mada51589
05-03-2022 08:54 PM
handsom-hustla
11-13-2015 05:04 PM
