Light Bulb need help please
Old Aug 14, 2015 | 12:29 AM
QuickTL07's Avatar
Hey guys, been looking around and cant find a damn light bulb,
I want to replace it, its lights up the gear shifter.. just to give you a better example.
Thank you for the help.
Old Aug 17, 2015 | 05:49 PM
THTL's Avatar
OEM Acura TL 2005 SELECT LEVER parts
Old Aug 17, 2015 | 06:06 PM
guitarplayer16's Avatar
Are you looking for the bulb to buy or are you looking for where the bulb sits lol
The bulb sits near the N indicator underneath it.
There's a skinny wire for it I believe. It's not like the other bulbs where you twist on and twist off the bulb.
This bulb actually has a small wire, just follow it, and twist it out of the shift assembly. Then once it's out of its place, you can pull the bulb straight out and push a new bulb in.
Old Aug 18, 2015 | 12:44 PM
THTL's Avatar
Do you know the OEM part number for this bulb?
Old Aug 18, 2015 | 12:57 PM
QuickTL07's Avatar
Originally Posted by THTL
Thank you for the link, and yes its all in this link for the light bulb that i need, its right inside of the shifter as other user mention, it has small wires going in to it, i wanna get blue led to match everything, the light bulb is a T5
Old Aug 18, 2015 | 01:23 PM
OEM part number is: 35505-S30-003
I assume you got it all figured out now
Old Aug 19, 2015 | 11:56 AM
QuickTL07's Avatar
Thank You
Old Aug 19, 2015 | 11:59 AM
QuickTL07's Avatar
This is going in there to match the shiffter buttons, I have a car audio build on here check it out,,, i have relocate the controllers for HAVC
T5 17 2721 286 74 37 12V Bright Blue 5mm LED Interior Dome Trunk Light Bulb Lamp | eBay
BoricuaTL
Apr 8, 2016 01:08 PM
sockr1
Oct 1, 2015 01:31 AM
Greengecko
Sep 16, 2015 08:19 PM
brjones9
Sep 3, 2015 07:30 PM
Mcj270
Aug 31, 2015 04:45 PM
