LG Envy 2, LG Voyager and LG Dare
Gang--
I roll a 2007 TL-S and was curious if anyone had success or trouble pairing any of these phones. I don't want to buy one unless I know it'll work. I use it with my current phone and with the cell phone laws in L.A., it's a necessity.
Also, how about the bberry Curve? Any help would be appreciated.
LG Envy 2
LG Voyager
LG Dare
Blackberry Curve
Best,
Kyle
LG Envy 2
LG Voyager
LG Dare
Blackberry Curve
Best,
Kyle
The DARE works fine with my 04 and it's officially compatible. Not sure aboue the others you listed, but you can check here:http://www.acura.com/models/handsfre..._index_new.asp
I sometimes have problems with my Dare and my 05. It will be paired but there will be no audio for either party. This is only occasionally, though, and turning off the phone and then turning it on again usually does the trick.
I have problems with the Dare in my 06. Same audio problem where no one can hear each other. It drops calls or you tell the car to answer the phone by pushing the button and it just doesn't want to connect. I usually will have to be the one to call someone by using the phone itself and then telling the car to transfer in order for the blue tooth to work correctly.
In Search Of Sunrise....
been using the ENVY-2 for the past 4 months now.. works like a champ. No issues here. Battery life is incredible, even with B-tooth on 90% of the time.
King of NYC
Just wanted to tell you guys I have an LG Dare now and it worked fine at first but then had a few glitches. I found out it had software version 3 in it. I went to the Verizon center and had it updated with version 5 and it is perfect now and it specifically addresses a bluetooth glitch.
5th Gear
i'm not sure what version i have on my phone right now. the only issue i have with the lg dare is when i recieve a call and press the hfl, the call goes to the phone. i have to press the speakerphone button on the dare twice to get it to transfer to the car. i'm gonna try to update the software tomorrow at verizon.
I have had a Blackberry Pearl and a Blackberry Curve, both will transfer the phonebook, you just have to make sure that the BT security level is set to High and not High + Encryption.
<P>
</P>
<P> </P>
Gang--</P>
<P> </P>
<P>I roll a 2007 TL-S and was curious if anyone had success or trouble pairing any of these phones. I don't want to buy one unless I know it'll work. I use it with my current phone and with the cell phone laws in L.A., it's a necessity.</P>
<P> </P>
<P>Also, how about the bberry Curve? Any help would be appreciated.</P>
<P> </P>
<P>LG Envy 2</P>
<P>LG Voyager</P>
<P>LG Dare</P>
<P>Blackberry Curve</P>
<P> </P>
<P>Best,</P>
<P> </P>
<P>Kyle
<P> </P>
<P> </P>
<P> </P>
<P>LG Envy 2</P>
<P>LG Voyager</P>
<P>LG Dare</P>
<P> </P>
<P>Best,</P>
<P> </P>
<P>Kyle
<P> </P>
