LEDs installed (Night Pics)
08 TL Type S A-Spec
Ok. 1st, THANKS TO Kennedy..........his threads/posts were very helpful. I went with V-LEDs for all my LEDs, I just took Kennedy's advice & slightly modified it using V-Leds for my order.
Here is what I did:
4 INTERIOR DOME LIGHTS -- HID White 6 LED bulbs (size 194)
2 Door/Courtesy Lights -- HP LED White Multi socket BOARD LED (size 194)
1 Glove Box Bulb -- SMT HP White Wedge Base Bulb (size 74)
2 License Plate bulbs -- HID White High Power License Plate Kit (size 194)
2 Reverse Bulbs -- SMT 18 LED White (Tower) Bulb (size 921)
**I accidentally only ordered ONE of the HP LED White boards for my door lights, so I am waiting for V-LEDs to ship out another one. For $12.99, I thought I was getting 2 of these babies........not ONE. SHEESH, these are PRICEY!!
Ok...................Here are some photos!!!!!! Enjoy!!
AND NOW................The REVERSE & License Plate LEDs:
Take a look at how much LIGHT gets all the way down on to the STREET from these new License Plate LEDs!!!! WOW!!
Take a look at how MUCH BRIGHTER THE REAR VIEW CAMERA IS.......NICE!!
These BULBS are a "COOL WHITE" color...........similar to HID. They are not BLUE, but the camera makes them look a little BLUE.
Here is what I did:
looks sick but they are far from hid.. they are LED's lol i have all done to my car as well.. i just ordered the led license plate and reverse lights.. i heard the license plate leds burn quick. so let us know if you have any problems
Here is what I did:
Here is what I did:
I would like to do the same thing for my TL. If its not any trouble, can you briefly describe how to get to the dome lights so I can replce them? thx !
Mod Edit: Edited for easier viewing
NTMD8
Thanks for these pics man.. i plan on doing exactly what you did and order direct from V-LEDS...but only thing that worries me is they look very blue in the pictures and i wanted something white like sixsixfour's setup. Can you confirm that they are white and not that blue?
Also did you order the SMT 6 LED boards ot the M-SMT LEDs?
Received 6,470 Likes
Vegas, what did all those bulbs cost you?
All the world's a stage
quick question about the license plate bulbs. are the ones you got plug and play or do you need to modify anything? also, how many bulbs would I need?
I'm going to place an order for the License Plate LEDs through V-LEDs.com. Quick question to confirm - a set comes with 2 bulbs for $9.99, right? And all I need is 2 bulbs, correct?
Thanks!
Thanks!
Master Tasker
I agree with Vegas that the 6 LED light is the way to go for interior on my 2005 TL. I have both the 6 and 4 LED, and the 4 is simply not bright enough.
Has anyone replaced the High Mount Brake lights with LEDs? I can't seem to get the cover off to see what bulb is needed - is it the same as the tail lights? The sylvania cross reference simply says "assembly". Does that mean it's a complete assembly that needs to be replaced?
Also I tried to get at the trunk bulb but can't seem to get the cover off. I started to pry at it, but don't want to break it and it isn't moving at all. Any recommendations?
For trunk light, theres a clip similar to the rear cabin lights
AZ Community Team
Received 7,771 Likes
I thought the trunk lens was the same/similar to the Vanity Lenses? Pretty Sure.
The Vanity Lenses are PITMFA. Thats one engineer that should roast in hell for all eternity, replacing burned out 3G Vanity Mirror Bulbs.
Master Tasker
Originally Posted by jmkiang
^ Seriously. I've been prying and prying for a couple days already.
The trunk is the same but it's much, much more tightly in place. If I recall correctly, I had to access the tab for mine from the right (passenger side) of the lens.
Hope this helps.
NBP REPRESENT
which led's would i need to order for the license plate and the backup lights?
appreciate it...looking for the hyper white or blue whatever color that is
is it just swapping bulbs or do i have to rewire anything?
thanks
thanks
guys what's your recommend of these 2 INTERIOR DOME LIGHTS. Should i order 2 SUPER HID WHITE 4 LED WEDGE BASE 194_4_W or 2 HID WHITE 6 LED LIGHT BULDS 194_6_W short.
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
NTMD8
I wouldn't get neither of them, cause it just wouldn't be bright enough for the interior.. if you do get them, everything will look dim and dark.
I would get these.
Plus for the front dome lights the bulbs are plugged in horizontally, so the light output would NOT be projected downward.
Rear dome lights are facing downward so the ones you posted might work back there, but it won't be bright enough IMHO.
I would get these.
Master Tasker
5 LED 'tower' link
6 LED Link
Master Tasker
I would get these.
I would get these.
NTMD8
Looks like jimsta and I were posting at the same time. The 11 SMT certainly would work, and would be much brighter than the 5 LED bulbs I am using.
Also i would add that for myself I actually picked up the 6 SMT Flank LEDs but it didn't work out too well ,cause they are polarized(meaning they have to plug in a certain way), so for the front domes, the driver side was facing downward while the passenger side faced upward into the dome which was just retarded. So i just used those for the courtesy lights and the SMT towers for my front domes.
Yeah i had 4 bulds of 6 SMT Flank LED it doesn't work too well for front and rear. that's why i need you guys recommend for the right one. For those 6 SMT i might put it in the door side it works ok. Thanks for Both of You
hey can u give me a link to the 2 Door/Courtesy Lights -- HP LED White Multi socket BOARD LED (size 194)?
im having troubles finding it.....and could u check if these are the right sizes
http://www.v-leds.com/Shop/Control/f...29236239234235
http://www.v-leds.com/Shop/Control/f...31244241248245
http://www.v-leds.com/Shop/Control/f...37232237244251
There pricey but holy crap there bright. I just put them in 5 min ago and I am very satisfied with them.
rockyboy
08-04-2024 10:35 AM
TLDude876
12-28-2016 03:18 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
