L/R Volume Difference w/Aftermarket Install
Old Dec 22, 2013 | 06:06 PM
ELDeFontes's Avatar
I have a very audible volume difference between the left and right sides of my car; the passenger side being the weaker side.
I am currently running off stock hu, wired LOC pre-amp, which goes back to the following...
Mosconi 6to8 DSP->Mosconi 120.4->Arc SE 2075 -> Nak PA 1500.
I was told to remove the LOC and to wire my RCA directly into the pre-amp signal.
I was hoping that before I went ahead to do this that this will resolve my issue and would like to hear from others before hand as well.
Old Dec 22, 2013 | 08:55 PM
ELDeFontes's Avatar
To clarify - both sides of the LOC are exactly equal.
Old Dec 23, 2013 | 01:05 PM
pohljm's Avatar
That would at least remove the LOC as a possible issue.
Old Dec 23, 2013 | 08:53 PM
Kirk3272's Avatar
Processor input/output set the same on both sides? The mosconi has several areas where L/R could be off. Any of the amps mentioned have separate L/R gain controls?
Old Dec 24, 2013 | 12:19 AM
ELDeFontes's Avatar
The only amp with L/R input is the Arc SE, which run the rears.
Once it stops raining, I'll jump on the 6to8 and check out the L/R sides.
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
lland
Oct 4, 2015 04:47 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
DRR98
1G RDX Problems & Fixes
Sep 2, 2015 10:52 AM
