Keyless Receiver issues
Old Sep 15, 2009 | 12:54 AM
CdTriX's Avatar
So i posted this in the problems and fixes but no one had an answer to the electrical tests.
Originally Posted by CdTriX
here is the input test.
so with my basic electrical knowledge, cavity 1/blk is ground.
so with a multimeter, i'm suppose to test the volage between the ground and the other pins?
the battery voltage is 12v DC correct?
pins 1 to 3 should be 12v
pins 1 to 5 should be 12v
pin 2 should be plugged into N No 1 (45P) at the relay box disconnected.
pin 2 to ground and should be no continuity
what does continuity mean?
Old Sep 15, 2009 | 12:05 PM
LoveMyTL-S's Avatar
Continuity means the circuit is complete when power is applied.
Def:
Continuity refers to being part of a complete or connected whole. In electrical applications, when an electrical circuit is capable of conducting current, it demonstrates electrical continuity. It is also said to be “closed,” because the circuit is complete. In the case of a light switch, for example, the circuit is closed and capable of conducting electricity when the switch is flipped to "on." The user can break the electrical continuity by flipping the switch to "off," opening the circuit and rendering it incapable of conducting electricity.
Old Sep 20, 2009 | 07:54 AM
BlueTypeSGuy's Avatar
Black is ground. Continuity in this context can also mean "short". Pin 2 to ground should be no continuity, means it should not be shorted. Hope this helps.
tman570
Jun 11, 2019 07:56 AM
Chief F1 Fan
Motorsports News
Sep 21, 2015 09:39 AM
carz0159
Sep 20, 2015 06:11 PM
GraveDigger
Sep 18, 2015 07:46 AM
MistaWet
Sep 15, 2015 08:26 PM
