Key fobs completely unresponsive '04 TL
New member here. Just bought a '04 TL with 156K miles on it. Person I bought it from said I just needed to replace the batteries in FOBs which I hastily didn't question. I've replaced the batteries in both of the FOBs and neither work. No lights flicker, no noises...nothing. I've tried to re-program them but may not have done it correctly. Either way, can someone tell me what the different issues could be so that I may troubleshoot? Many thanks in advance!
Check out this thread.
Also, check the FCC codes on the back of the keyfobs, which should read OUCG8D-387H-A IC: 850G-G8D387HA and below these it shows GHD-387HA. If not the same, won't work.
Thanks for the reply. One of the fobs has a sticker which has both those numbers that you listed and also says "memory 2" at the bottom. The other FOB (I'm assuming is "Memory 1") does not have a sticker at all - previous owner wore it off, so I don't know. Is it possible the receiver in the car located near the firewall behind the steering column is bad?
