K&P Technologies 10% off code....window roll-up mod anyone?
Old May 8, 2009 | 07:43 AM
  #81
georgegiorgio's Avatar
G Force
Originally Posted by LoveMyTL-S
Well, I installed mine (direct solder method) and it's not working. All the original functions of the FOB still work. I did break one wire but soldered it back together. Can some please post up what color wire from the module goes to what wire in the car so I can double check my wiring? Any help is really appeciated.
Thanks........
KP Red --> Acura Big Green/white stripe
KP Black --> Acura pure Black
KP Yellow --> Acura pure Yellow
KP Blue --> Acura Yellow/black stripe
KP Green --> Acura White/red stripe(on large white window module)
Old May 8, 2009 | 08:52 AM
  #82
LoveMyTL-S's Avatar
Thanks so much. I'll have to double check my wiring.
Old May 8, 2009 | 10:00 AM
  #83
rodneyc77's Avatar
Retired!!! ON TOP!!!
the Acura Yellow / Black Stripe is on the branch where the designation 10/11 is pointing to in the following picture:
You have to open up the white plastic weather barrier/vapor barrier and look for that wire heading towards the lock mechanism... I can assure you that you have the wrong yellow/black wire tapped...
Old May 8, 2009 | 10:07 AM
  #84
kpierson's Avatar
You really should use a volt meter to verify the wires BEFORE you make connections. It is possible to damage the module by hooking it up incorrectly. The Acuras have multiple wires of the same color inside the door.
Due to the higher then normal number of issues we have with customers installing these in Hondas we have included a diagnostic LED in every unit that shipped during this promotion. The super bright blue LED can be seen by looking in the hole in the module where the wire harness passes through.
If everything is hooked up correctly this is how it should work:
1. Press the "LOCK" button on the remote - the BLUE LED will light up for the duration of the lock event and then turn off. If the module is not doing this verify the red wire is hooked to constant power, the black wire is hooked to a good ground, and the blue wire is hooked to the lock actuator. The yellow wire should be disconnected from the vehicle IF the LED is not lighting up during this step to eliminate it from the equation.
2. Once the LED turns off press the "LOCK" button again and the LED should come on and stay on for ~10 seconds while the windows are going up. If the LED comes on but the windows don't raise up then the green wire needs to be rechecked to make sure it is connected to the correct wire.
If the windows stop while going up the LED will shut off then flash. I believe two flashes means the unit saw a lock pulse which shut the output off and three flashes is the ignition (yellow wire) was turned on (or had 12vdc applied to it).
Again though, it is imperative that a volt meter be used to verify wiring!
Old May 8, 2009 | 03:52 PM
  #85
CubanLynx84's Avatar
under renovations....
if anyone needs help wiring this up and is local Bx and lower Westchester I dont mind helping out I did mine with no problems and it works perfectly.
I think alot of you guys are use the wrong YELLOW/BLACK stripped wire and thats what's causing all the confusion. As stated you do need to cut the vapor barrier a little to access the wire. it's there just look real closely at the pics that were put up in the intsall thread. one pic is missing though but from the rest of them you can see the wire and it's location.
Old May 8, 2009 | 09:57 PM
  #86
Timb227's Avatar
Fear and Loathing in my
Just did this install about a week ago, didn't work at first, so I went back in and re-tightened all of my connections and it works like a charm. I love walking away from my car with all the windows down, then hitting lock twice and just watch my windows roll up, LOVE it everytime lol. Follow this DIY carefully, check everything twice and you should have no problems installing it yourself.
https://acurazine.com/forums/showthr...t=technologies
Old Sep 14, 2009 | 07:19 PM
  #87
kpierson's Avatar
For a limited time, use the code "370Z" to get a 20% discount off all products at www.KPtechnologies.com!
Old Sep 15, 2009 | 12:02 PM
  #88
blokhead's Avatar
PCM full of water, yummy
Tried to order and it gave an error when I hit the place order button...
Old Sep 15, 2009 | 12:13 PM
  #89
LoveMyTL-S's Avatar
Is the wiring different for the 07/08 Type-S? I wired mine with these instructions and it didn't work. Haven't had time to fiddle with it yet.
Old Sep 15, 2009 | 12:20 PM
  #90
dwb993's Avatar
I used the same instructions on my 06. Check out post #375 where I mention the most helpful image of the whole thread. Hope it helps.
BTW, for anyone who has not already installed this---this is probably the #1 favorite mod I have done to my car. I use it every day and have been very happy with the ease of install, operation and durability. Highly recommended, especially with 20% off!
Old Sep 15, 2009 | 01:01 PM
  #91
LoveMyTL-S's Avatar
I'll check out post #375, thanks.......
Old Sep 15, 2009 | 02:37 PM
  #92
kpierson's Avatar
I just tried it and it worked - try again.
Did you verify the wiring with a volt meter? There are multiple wires of the same color - a volt meter is the only way to make sure you have it 100%.
Old Sep 15, 2009 | 11:23 PM
  #93
nicourt's Avatar
WoW 20% off I just ordered one!!! This is going to be sweet!!!! Thanks Kpierson for the hook up!
Old Sep 16, 2009 | 07:04 AM
  #94
LoveMyTL-S's Avatar
No I didn't. I'll have to do that. Thanks.
Old Sep 16, 2009 | 08:03 AM
  #95
godizus's Avatar
Needs wheels
nothing like a $40 mod....hmm....
Old Sep 28, 2009 | 03:41 PM
  #96
mpdrew's Avatar
is this code still good for 20% off and which one is the correct one for the window up AND sunroof close on a 07 TL? Is it the item# HM20 for 49.99? Thanks.
Old Sep 28, 2009 | 03:53 PM
  #97
G Force
One module rule them all....
I got it a while ago, and it works like a charm.... close all windows including sunroof...
My friends with Bimmer/Benz/Lexus/Audi are what the heck?! How come Acura does that?!
Old Sep 28, 2009 | 09:56 PM
  #98
HQTL6SPD's Avatar
Could anybody explain why mine worked fine for a month, and then just doesn't work at all?
I followed installation instructions carefully.
Even used the snap on style crimps.. it's supposed to be a solid connection, don't know what it could be at this point...
Old Sep 29, 2009 | 08:06 AM
  #99
dwb993's Avatar
Most likely a bad connection and/or fuse. Check with the vendor (kpierson), as he is a member of AZ and has been very supportive.
Old Sep 29, 2009 | 08:08 AM
  #100
LoveMyTL-S's Avatar
Yes, HM20 is the correct module.
Old Sep 29, 2009 | 08:10 AM
  #101
mpdrew's Avatar
thank you
Old Sep 29, 2009 | 08:12 AM
  #102
KN_TL's Avatar
I just tried the two codes in this thread and none of them work....bummer.
Old Sep 29, 2009 | 08:21 AM
  #103
mpdrew's Avatar
and it appears the code 370Z is no longer valid. sucks
Old Sep 29, 2009 | 08:29 AM
  #104
LoveMyTL-S's Avatar
PM kpierson for the code.
Old Sep 29, 2009 | 08:59 AM
  #105
mpdrew's Avatar
cool. i did...now just patiently awaiting a response. thanks
Old Sep 29, 2009 | 01:31 PM
  #106
thait's Avatar
I need a car in
if the code works im ordering it!....
Old Sep 29, 2009 | 01:46 PM
  #107
mpdrew's Avatar
i couldnt get the code to work. it went through, but without any discount so I'm trying to cancel the order and wait for a new code sometime down the road.
Old Sep 29, 2009 | 02:15 PM
  #108
LoveMyTL-S's Avatar
Did you get the promo code from the vendor?
Old Sep 29, 2009 | 03:04 PM
  #109
mpdrew's Avatar
i tried to use the 370Z which was provided by kpierson a few posts up, but seems to be invalid at this point. PM'd him to see if there was a new one, but no response back yet. cant find an email for him so can only PM and wait patiently. unless you have contact info you can help me out with? thanks
Old Sep 29, 2009 | 03:42 PM
  #110
dwb993's Avatar
Is there contact info on the website?
Old Sep 29, 2009 | 03:52 PM
  #111
mpdrew's Avatar
just a business email. no phone # or direct email for kpierson. i emailed it this morning requesting my order be cancelled, but have not received a response yet.
Old Sep 30, 2009 | 06:33 PM
  #112
Silva95teg's Avatar
06 WDP/Ebony MT NAV ASPEC
I am interested in ordering one but i am in canada. Does anyone know if they ship usps into canada or do they use ups ? Ups Rapes us in brokerage fees.
Old Oct 23, 2009 | 09:50 AM
  #113
dommafia's Avatar
04TL4L
do you have any updates on this yet?
this looks like a great and cheap mod to do next on my car myself!
I hope kpierson puts up a new code soon.
Old Oct 23, 2009 | 09:58 AM
  #114
kpierson's Avatar
We arn't currently offering any discounts.
We ship all orders UPS - the customer is repsponsible for all brokerage fees and taxes.
For the fastest technical support Email us through our site - for some reason I stopped getting Emails from Acurazine about PMs and thread updates.
Old Oct 23, 2009 | 10:00 AM
  #115
kpierson's Avatar
OK, I just created a 10% off (for now) non expiring coupon for Acurazine - use the code Acurazine when checking out!
Old Oct 23, 2009 | 10:06 AM
  #116
dwb993's Avatar
Yay, kp!!!
Old Oct 23, 2009 | 11:01 AM
  #117
LoveMyTL-S's Avatar
I updated the thread title to reflect the 10% vice original 20% discount.
Old Oct 26, 2010 | 02:09 PM
  #118
Abe_Froman's Avatar
Anyone got the latest promotion code?
Old Oct 26, 2010 | 05:42 PM
  #119
Abe_Froman's Avatar
Promo code "acurazine" will get you guys 10% off.
Old Oct 27, 2010 | 08:28 PM
  #120
WhiteBB2's Avatar
SlowAnthony
Wish it was still 20%..
