JL Audio Clean Sweep Issues?
Old Feb 23, 2011 | 09:31 PM
Toro_Bravo's Avatar
6th Gear
Question JL Audio Clean Sweep Issues?
Has anyone tried the JL Audio Clean Sweep? Does it work well with the factory radio or are there any issues with it?
Old Feb 23, 2011 | 09:49 PM
jda123's Avatar
Dogmatic Dinosaur
You can use it. You don't need to signal sum on this car. The pre-amp signals are full range for the front and rear.
Old Feb 24, 2011 | 08:38 AM
Evolution22's Avatar
im thinking of doing the same is there anything else i need to get to use the clean sweep?
Old Feb 24, 2011 | 11:38 AM
DiamondJoeQuimby's Avatar
Codename Duchess
amp and new speakers
Old Feb 24, 2011 | 05:06 PM
cjj2d's Avatar
I assume this would hold true for a 3sixty.2 as well?
I was wondering if I should sum the signals.
Old Feb 24, 2011 | 05:25 PM
jda123's Avatar
Dogmatic Dinosaur
You do not not need to sum the front, rear and subwoofer channel to get a full range signal with the TL radio. The signal summers were created for cars (and there are many) where no single signal is full range.
If you want to processes the signal, then get a 3sixty, JBL MS8 or an Audison bitone.1. If you just want to use some components on crossovers, then the low level input on your amp, or a LOC with RCAs, will work just fine and sound a million times better than stock. If you want 2 million times better, then buy a processor.
sockr1
Oct 1, 2015 01:31 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
vanderveen44
ILX
Sep 2, 2015 01:48 PM
