Jealous of '06 TSX Owners Nav
The 07 TLs? Im thinking more of the 06 TSX units in the TL. But with people saying the unit along is like 2,000, its an expensive change. Really want the screen to look like that though.
Youse Gots Sacked
im sure that the 07 TL's will be much better than the 06 TSX Navi....i would bet my life that the TL will have the Zagats Survey shit.....and the TL will have a nicer set up....plus there are some features the TL has that the TSX dosn't have so not all features would work...
Silky Smooth
Originally Posted by acura101west
yep 2006 tsx has better navi and voice controls then the TL
its due to the fact tsx comes from japan and TL is made in the USA
its sad
its sad
keep your mouth shut..
Originally Posted by Lokius
that is simply the stupidest thing I have ever heared. the navi unit is more than definently not made in the USA for either the TL or the TSX... having it built in japan doesnt make the electronics better, the navi unit is newer, once the tl is updated it will be better again in 07....
I wonder if swapping the bootstrap file would work like it does now on our nav disc. I'm running the '05 TSX bootstrap to get the trip computer on the nav screen. Has anyone tried that yet (I would if I could get my hands on the new disc).
Registered User
Wants an M3 in
Originally Posted by rbf351
the drives are different, so you would need to get the drive and the software
Registered User
Are the drives just like regular computer drives? If so, what's to stop you from backing up the data on the disk and then overwriting it with the data from the TSX? I haven't pulled apart the nav myself to see what its like but I'm sure you could interface with the drive somehow to extract the data.
Simply swapping the new TSX navi DVD disk into our TLs probably won't do it. My guess is the DVD is just a newer version and will have updated maps for the TL, but the interface will be the same. The DVDs we currently use have software versions for multiple acura/honda vehicles, but something in the nav hardware unit forces it to load a certain software version.
You could try to use the trick others are using to enable the trip computer in our TL. Basically, copy the file the new TSX is currently using, but rename it to the file the TL loads. Then burn it to a CD and load it using the diagnostic screen (the same way as described in the hack navi thread or the trip computer thread). If the hardware hasn't changed too much, the new TSX software should load. You'll have the new interface with Zagats but don't expect any speed improvement (if anything, should be slower).
Now if it fails to load, you're on your own. Hopefully, if you disconnect the nav unit from the battery long enough, you can get it to reload the old software from the original DVD.
Registered User
Youse Gots Sacked
Originally Posted by NFLblitze1
can somebody do some trial and error with this? if the TSX navi software and hardware indeed did not change...then it just might be possible to have it show on the TL Navigation
you must be a kid to say that
tsx and mdx run same system now and tl still gets the old one,yes thats a fact ,i work at the dealer stupid fuck!!
thats what i ment by made in amercia,so before you open your stupid mouth please know what your talking about
Youse Gots Sacked
Last time I was at my dealer they didn't have any '06's otherwise I would've snagged a disc and copied it. I'd be willing to be the guinea pig if someone posted the files. Of course if it worked, I would legitimately buy the disc
mugen_kid
11-13-2015 10:38 PM
Rocktman1
09-19-2015 05:58 PM
asahrts
09-04-2015 05:55 PM
