iSimple stopped working. "does not recognize accessory"
Old Aug 8, 2014 | 03:30 AM
Fatfrii's Avatar
using 5s. does not work anymore on either aux1 or ipod mode. plugging adapter first into phone does not fix it (which has helped before it stopped working). so far i have disconnected the module and the battery and let it sit over night and still no fix. The problem started when someone plugged in their 4s.
I briefly looked into upgrading the firmware but the instructions are so vague. has anyone else had this issue or can give me details on how to update the firmware.
http://www.pac-audio.com/Firmware/connect/index.html
Old Aug 8, 2014 | 03:46 AM
Fatfrii's Avatar
another thing i that before i disconnected it and let it sit over night, it said "BT" instead of AUX1. I was thinking it had to be bluetooth but this device doesnt have blue tooth. it is a few years old. I remember a few years back there was and IOS update and i had to get the chip upgraded in the isimple. I am very very confused.
Old Aug 8, 2014 | 10:10 AM
pohljm's Avatar
You need to take the module apart and short out the leads to the large capacitor in the group of capacitors. That will reset the device
Old Aug 9, 2014 | 12:21 PM
Fatfrii's Avatar
I just tried this. it did not change anything.
Old Aug 9, 2014 | 12:29 PM
pohljm's Avatar
Then you have problems
Old Aug 9, 2014 | 06:56 PM
Fatfrii's Avatar
it works on aux2 mode so the device cant be completely messed up. there has to be something i can do
Old Aug 9, 2014 | 08:53 PM
pohljm's Avatar
call customer service they are pretty good
Old Aug 11, 2014 | 06:33 PM
Fatfrii's Avatar
turns out the cable was bad. swapped it with an extra one i had layin around and everything is back to normal except for the next track button on my steering wheel. I have reads other complaints about the same issue.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rboller
Sep 23, 2015 02:49 PM
