iSimple question
Old Mar 20, 2009 | 06:59 PM
wolfpackNC's Avatar
iSimple question
I installed the iSimple with no problems and I love it, but I have one question. If I turn my radio off via the power button before I turn my car off, when I start it back up it takes a 3- 4 minutes before the XM or Ipod will work. When I hit the XM button, nothing happens. FM, AM and CD all work fine. Is this normal?
Old Mar 20, 2009 | 07:03 PM
Trew's Avatar
It sounds like the iSimple unit is taking a few minutes to power up after you turn the radio on. I have never noticed this because I usually just turn down my radio rather than turn it off.
I'll try turning it off and see what happens.
Old Mar 20, 2009 | 09:07 PM
PeterUbers's Avatar
you'll get better reliability by leaving the radio on before turning the car off. For whatever reason, it takes a while to "boot" so to speak when you turn the car off after you've powered down the radio.
I get the same thing sometimes. I never turn my radio off, i'll just turn the volume down.
Old Mar 21, 2009 | 08:14 AM
borgit's Avatar
Wasn't there a firmware update that supposedly fixed this? I think it was .26. Which firmware revision are you running?
Old Mar 21, 2009 | 02:06 PM
wolfpackNC's Avatar
I'm running .36, which is what it came with. When I tried to upgrade, it said I already had the latest firmware.
I just wanted to make sure it was not doing something that will cause my stereo to get fried.
Old Mar 21, 2009 | 02:56 PM
AMIC's Avatar
Fightin' Texas Aggie
There are still a few issues with the firmware. I would bring up your issue in the main iSimple thread. A representative of Peripheral checks that thread regularly and does respond to questions and comments.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/question-reliable-2004-2008-acura-tl-direct-ipod-input-aux-level-4-a-635351/
Old Mar 21, 2009 | 04:54 PM
Trew's Avatar
Ok I just tried this. With the iPhone still connected, I turned off the radio, then shut off the car and pulled the key. I waited 30 seconds or so, then restarted the car and turned the radio back on. The input was still on iPod mode and the song I was playing instantly picked up right where it left off.
I am also running .36 firmware. Not sure what you tell you.
Old Mar 22, 2009 | 11:44 AM
nhousepro's Avatar
I have the same issue with my Zune set-up. I just hit the mode button on my steering wheel and all is good from there.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
