iSimple/PXAMG help!
Received 3,824 Likes
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I bought the car used (06 with navi) and it has the iSimple or PXAMG iPod attachment. Being that it's 6 years old the piece that plugs into the iPod is worn out. If I go over bumps the right side speakers fade in and out and it plays really low and maintains normal volume on my driver side.
Is there a way I could just buy the cable that hooks into the iPod and radio instead of buying the whole iSimple kit? It's like almost $200
That does not happen when listening to non-iPod music??
I have had loose connections to an I device and that did not happen, sounds more like a cable loose behind the stereo for the Isimple. If it uses RCA connections - one is semi loose
Undying Dreams (04-19-2012)
Dogmatic Dinosaur
You can buy a new cord for your iSimple. I have replaced one already.
...something like this, but make sure you get the right one for your unit.
http://www.ebay.com/itm/ISPDC11-iSim...#ht_540wt_1046
Yes, it's just with the iPod. CD's, tape and radio work fine. Hmm, I guess I'll have to pull the center console and check. Only thing is...I have no clue how to do that...anyone have pics/instructions?
It plugs in down by the gas pedal right?
Nevermind, found a video on youtube on the whole install. Just gonna pull up the center console and check cables and such. I'll report back in case anyone else has this problem.
Do I need to disable the battery before I tear the dash apart? The radio has that Anti-Theft thing.
the overexplainer
when working with sensitive electronics it's always best to disconnect the battery.
Your anti theft code is either in your user manual/folder or your dealer has them.
Undying Dreams (04-22-2012)
