iSimple - auxiliary out 3.5 MM
I have a 2006 Acura TL. I currently have an iSimple in my TL. I want to know if I can hook up auxiliary input in and run it to the center console and run the blackberry music gateway.
Is this setup possible?
Yes.
You should have received a separate cable with rca's and a 3.5 male to plug into your aux 2 connection with your isimple. This will allow you to connect your gateway
- iSimple's 1st port hooked up to the iPhone cable (I use this now for occasional recharging on road trips).
- iSimple's 2nd port hooked up to the cable that has an RCA/3.5mm plug, and that is plugged into the Blackberry Gateway (automatically connects to the iPhone 4S).
Works great!
mlody
12-04-2019 02:11 PM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
