iSimple - auxiliary out 3.5 MM
Old Jun 23, 2012 | 11:39 AM
Bulldoggie15's Avatar
I have a 2006 Acura TL. I currently have an iSimple in my TL. I want to know if I can hook up auxiliary input in and run it to the center console and run the blackberry music gateway.
Is this setup possible?
Old Jun 23, 2012 | 11:40 AM
guitarplayer16's Avatar
Yes.
Old Jun 23, 2012 | 04:31 PM
pohljm's Avatar
You should have received a separate cable with rca's and a 3.5 male to plug into your aux 2 connection with your isimple. This will allow you to connect your gateway
Old Jun 24, 2012 | 03:36 PM
triax37's Avatar
Yep, I have this exact setup:
- iSimple's 1st port hooked up to the iPhone cable (I use this now for occasional recharging on road trips).
- iSimple's 2nd port hooked up to the cable that has an RCA/3.5mm plug, and that is plugged into the Blackberry Gateway (automatically connects to the iPhone 4S).
Works great!
Old Jul 2, 2012 | 07:24 PM
quake97's Avatar
Same setup here. Works great.
Joe
mlody
Dec 4, 2019 02:11 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
