ipod and our head unit
Old Mar 23, 2005 | 11:18 AM
Obey's Avatar
LogJam claims to have a new interface that will allow us to use our IPODS with our factory stereos. http://www.logjamelectronics.com/piehon03pcpod.html They say it plugs into a CD changer output...Has anyone pulled out their headunits to see if a slot exists? Seems strange to have an output when it already comes with a 6 disc in dash. Like you all, I really hope to find a way to cleanly intergrate my IPOD! Thanks!
Old Mar 23, 2005 | 11:21 AM
cM3go's Avatar
moved to audio forum
Old Mar 23, 2005 | 11:23 AM
cM3go's Avatar
says:
IMPORTANT APPLICATION NOTES:
Works with the following non-navigation equipped vehicles with or without the 6 disc in-dash CD changer
Bummer
Old Mar 23, 2005 | 03:09 PM
PeterUbers's Avatar
Sounds like a cool deal .. only $159.00 ... looks like it has the 10-pin connector on the end of the lead wire. Hope it's legit..
PeterUbers's Avatar
Old Mar 23, 2005 | 03:12 PM
PeterUbers's Avatar
Old Mar 23, 2005 | 04:15 PM
vp911's Avatar
Originally Posted by cTLgo
says:
Bummer
Old Mar 23, 2005 | 05:25 PM
Obey's Avatar
THE COMPANY IS 100 PERCENT LEGIT! I HAD A SIMILAR UNIT IN MY 99 ACCORD AND IT WORKED AWESOME. I just want to make sure there is a slot for that harness to plug into. I talked to the maker and they claim it will work perfect. My question remains, has anyone inspected the back of their head unit?
Old Mar 23, 2005 | 05:33 PM
PeterUbers's Avatar
What about XM radio functionality? Seems like this was a hang-up issue w/ the Blitzsafe...
Old Mar 23, 2005 | 05:34 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
I guess this could be considered one downside to having Navi.
I wonder when they're going to start shipping this thing.
Old Mar 23, 2005 | 05:35 PM
TLover's Avatar
No navi, so here's it works.
Old Mar 23, 2005 | 05:36 PM
Obey's Avatar
I assume they are working around it. . . which may be the reason for the delay.When I talked with the manufactor they kept talking about the cd changer input slot. So I would hope/assume that it would stand apart from the operation of the XM and in dash changer. I am just curious if the tape/cd button would change to the IPOD slot. On my accord I hit CD twice and it switched to my ipod. And it was fantastic, lossless sound!
Old Mar 23, 2005 | 05:47 PM
legionofdoom's Avatar
If this works well I might finally break down and buy an iPod... Anyone actually have it in their sweaty little palms yet?
-LOD
Old Mar 24, 2005 | 01:41 PM
PeterUbers's Avatar
So, w/ this installed on a non-navi TL, how would I access the CD player? Do I hit the CD/Tape button again to access CD's in my changer, or do I just turn off the PID device somehow and therefore free up the Cd player to play CD's?
Old Mar 24, 2005 | 06:56 PM
SilverJ's Avatar
this sounds right...
I was talking to a car stereo shop yesterday---they said they could install something similar for 175. Not IPOD specific--just basically using the cd changer as an aux in. I am considering...
By the way---I own an ipod and an Iriver H10 as well as a Iriver H-120---
No comparison in the sound. If you dont already own an ipod check out the iriver players. They sound way better.
Old Mar 24, 2005 | 07:01 PM
zax123's Avatar
Team Anthracite Member
I have a similar unit (minus the iPod control) in my car. I'm sure it's made by the same manufacturer cuz the box looks exactly the same. To access the AUX input, you just press the CD button twice and the head unit goes unit CD-C (CD Changer) mode. To get back to CD mode, you just press CD again. I have Navi in my TL, but it's a Canadian TL so I don't have XM radio. And I had to do the funky yellow-wire switch thing as mentioned in the famous Blitzsafe thread.
Old Mar 24, 2005 | 11:24 PM
jobes's Avatar
Team Nighthawk-C.M.A.
It will never come for us navi ppl
Brian:
Since we are just a retailer, plus we do not have the product yet from the manufacturer, we do not know what the manufacturer's plans are for this product. To date, this particular manufacturer, P.I.E., has not made any of the their Honda/Acura interfaces compatible with radios that have navigation. So going by that, I would assume that the chances of them making an adapter that is compatible with radio nav systems is possible but unlikely.
Thank you,
Technical Support
Logjam Electronics
techsupport@logjamelectronics.com
-----Original Message-----
Sent: Thursday, March 24, 2005 10:35 AM
To: techsupport@logjamelectronics.com
Subject: RE: Acura and NAVI
In the future will you have integration with navi?
Brian
Old Mar 25, 2005 | 05:24 AM
VelfarreClubber's Avatar
About damn time a product is out, or is it?
Old Mar 25, 2005 | 10:45 PM
Obey's Avatar
ILL TRY AGAIN :p Has anyone inspected the back of the stereo to see if this will plug in.......pretty please somebody answer me!
Old Mar 26, 2005 | 07:02 AM
PeterUbers's Avatar
http://www.robertcotran.com/persephone/
pics thanks to Zax123 and his amazing job in compiling a very detailed log of his audio/electronics install.
Old Mar 26, 2005 | 07:47 PM
maddog136's Avatar
Airline jet aircraft tech
Dash Unit connector descriptions
I am eagerly awating a fully functional I-Pod unit interface unit which will still allow XM to work. hopefully the PIE init is it. Here is some info on the Dash unit connectors.
The 3 Audio Unit connectors shown in the photo are as follows as per the Acura 2004 service manual, chapter 22-391-395:
Left connector C - 26 pin, has wires from dash unit to stereo amp unit for rear and door speakers, also contains signal wires from steering wheel remote switch.
Middle connector A - 20 pin, has wires from dash unit to stereo amp unit for subwoofer and front center speaker,
Right connector B - 14 pin(yellow arrow), all wires to/from XM receiver unit and dash unit.
From my experence with aircraft and automotive electronics, for the proposed PIE unit to work without disabling XM which is using the only external input(connector B) to the Audio Unit, it would have to use a pass-through or breakout connector which the XM harness would first plug into and then connect into the B connector. I have sent a info request to PIE at www.pie.net to confirm how they intend this item to interface with our dash units.
Old Mar 27, 2005 | 08:25 PM
Obey's Avatar
ok so you have to choose XM or IPOD - - clearly there is not a third slot for the cable by itself. wonder if they are working on a duel mode? Thanks everyone for posting... im still very interested in this unit?
Old Mar 28, 2005 | 01:06 AM
djdakine's Avatar
3rd Gear
sorry, i'm a little confused. Besides an FM trans or the cassette adapter, is there a solutiong for a Non-Navi, who doesnt use the XM (no XM here in Hawaii). I've read through these boards a few times, and saw someone reference to it...but never really found any direct information. Actually...I got lost between the Canadian TL thread of how they couldn't do it because instead of the AM/FM seperate button.
Jul 16, 2017 07:33 AM
TLguy42
Sep 26, 2015 11:27 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
