Ipod and Escort 8500 X50 install
Old Mar 9, 2007 | 08:04 AM
Levelpar1's Avatar
I just installed my Ipod and Escort 8500 X50. Here is a brief description of how I did it.
Ipod:
I used the aux. port in the arm rest. That connects to a Belkin Ipod dock adapter. The Ipod dock adapter plugs into the back of the Dice Cradle. The Dice Cradle is mounted to a PanaVise Custom In Dash Mount. I slide the Ipod into the cradle and hit play. The sound is great! When I start the car it powers up the Ipod in pause mode. Turn off the car and is pauses the Ipod and then turns it off.
Escort 8500 X50:
I used the suction cup mount that came with the Escort. I took the suction cups off and used 3M tape. The mount is stuck directly to the windshield. I used this same process on my 04 TL. I mounted the mute/power control in the bottom center compartment. That way I can hit it by closing the door.
Total Cost:
Ipod
Belkin Ipod Dock $12 on ebay
PanaVise Mount $21
Dice Cradle $49.95
Aux Cable $9.95
Total $92.90
Excort
3M tape $4
Old Mar 9, 2007 | 08:20 AM
Levelpar1's Avatar
Sorry Typo...
I mounted the mute/power control in the bottom center compartment. That way I can hide it by closing the door.
Old Mar 9, 2007 | 08:46 AM
BogeyBoy82's Avatar
what aux cable did you use and is it run to the aux in in the center console?
Old Mar 9, 2007 | 08:58 AM
Levelpar1's Avatar
I used a Monster Cable mini to mini headphone cable. The aux. cable is plugged into the port in the center arm rest. The other end of the cable plugs into the Belkin Dock Adapter. I set the volume on the Belkin Dock adapter. It sounds better than just plugging the mini headphone directly into the Ipod, plus it charges the Ipod and turns it on and off automatically.
Old Mar 10, 2007 | 06:43 PM
flipper2001's Avatar
bigger pictures tell 1000 words.
Old Mar 15, 2007 | 08:25 AM
jd34's Avatar
how did you hide the power cable for the escort all the way do to the consol,and where is the power coming from for that...
Old Mar 16, 2007 | 11:06 PM
fish008's Avatar
As far as the ipod goes is that hard wired or are you using an FM modulator? If it is hard wired what year is your car? what are you plugging into? If it is a factory input is it nav only. I have an 04 non nav and the dealership says there is no way to make it work and some local stereo shops don't know what to think, so I have no idea. ANY IDEAS? I need my ipod back in my car with some quality sound.
Old Mar 17, 2007 | 04:10 AM
datmrman's Avatar
^ Check out The 3G TL Audio & Electronics FAQ for iPod integration modules. They will work for cars with and without navigation.
Old Mar 17, 2007 | 07:22 AM
ThrotTLup's Avatar
NIce job!! I've been looking for a mount for my RX-65 (same as your Escort) and overlooked the simple but effective approach that you've taken. Thanks for posting.
Old Mar 17, 2007 | 11:22 AM
Ipod:
Escort 8500 X50:
Total Cost:
Ipod
PanaVise Mount $21
Dice Cradle $49.95
Aux Cable $9.95
Total $92.90
Excort
3M tape $4
Levelpar, I have the same Escort and it's hard to see from your picture where the cable that goes to Escort is. I have a 07 also and im using the same belkin as you from the center console but where is the wire going to the ipod dock, again its hard to see in that picture. The Ipod wire isnt a big deal because you just run it from the center console up to the top console and then there is a small indentation where you can run the wire out of that. Is this what you are doing to get it to the dock(ipod mount)? With the escort i always have to move the wire when i get in the car, i would love to see how you did this or post more information on it. thanks!
Old Mar 17, 2007 | 01:19 PM
rubaduckie's Avatar
Ipod:
Escort 8500 X50:
Total Cost:
Ipod
PanaVise Mount $21
Dice Cradle $49.95
Aux Cable $9.95
Total $92.90
Excort
3M tape $4
nice IPOD setup. How did you run your wires for the escort?
Old Apr 4, 2007 | 08:50 AM
Levelpar1's Avatar
Sorry for the delay on answering your questions. I ran the Escort wire under the headliner and down the piller on the drivers side. The fuse box in on the drivers side so it was a very was install.
When I removed the metal trim piece to install the Panavise mount, I tucked the Ipod wire under top of the of the trim piece then under the center console. If fit without and cutting. You can hardly see the wire. The Belkin Ipod adapter plugs into the back of the Dice Cradle.
I will take more detailed pictures.
Old Dec 11, 2007 | 08:20 AM
JROCKACURA's Avatar
i've been lokoing everywhere for this thread. I'm trying to install my x50 exactly like this but I'm not sure how to wire the smartcord mute button into the lower tray. Can you post a picture of the lower tray upclose and how you wired the mute button in.
I would assume you had to drill sometype of hole in the tray and that I was I am trying to avoid. Please advice on the best way to get the mute button into the bottom tray. The rest of the install is straight forward.
Also - is it OK to use 3M directly onto that (for lack of knowledge of what it is) black dotted area behind the rearview. Will it ruin that area if I ever take the 3M tape off?
Old Dec 11, 2007 | 09:10 AM
Evader's Avatar
Let's Go Pens
Great writeup. I have the same detector, however, my smartcord is located where the vsa switch used to be (just moved the VSA to the empty slot) Can you give me some more details on how you were able to get that compartment out in order to put the switch inside the door. Thanks!
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
ivegotthenav
Sep 11, 2015 07:51 PM
