iPhone 5 iSimple?
I'm fairly certain it will as long as you use a lightning to 30-pin connector since isimple uses the 30 pin connector. I have not tested this but there was a guy using his ipad mini this way.
Purple ashes (05-01-2013)
You can add an HDradio interface with this brand new iSimple unit and hook up your iPhone 5 via USB and Bluetooth streaming. Good luck finding one from a legit source. I called PAC and they were clueless as to where I could buy one so I said screw it and went with the USA SPEC. It's great but it does not have the HDradio option.
http://pac-audio.com/productDetails....&CategoryID=36
I have the ISHD651 but have yet to install. The HD Radio option was definitely one of the factors in me getting the product - plus the integrated BT module. The prior iSimple offering - ISHD571 - could have BT added on as an aux and for $100 extra, but the ISHD651 integrates it and for at a lesser cost. HD Radio option should still be the same add-on cost for this, however.
I had a review posted in a separate thread (#7):
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/isimple-ishd651-885908/
Hope this helps.. I don't have the HD Radio option installed as previously stated, but I could opt for it down the line.
mlody
12-04-2019 02:11 PM
Eggs999bacon
09-24-2015 10:08 AM
Vejey Gandier
09-12-2015 08:59 PM
