Intermittant Navi error message
Old Oct 11, 2004 | 07:51 PM
richmojm's Avatar
I am getting the following error from the '05 navigation system when I try to get directions to any address on a certain road. Other addresses work fine. Has anyone seen this?
"Route has not been completed. Please try again from a different location."
This error is mentioned in the navigation manual, and the solution is "This message will appear when you routing to or from a place (new area) that is not in the database. Try planning a different route to or from a different location."
However, the address is in the database (and I've successfully set up a route to it before).
This error occurs even when I am on a major road.
Thanks,
Jay
Old Oct 11, 2004 | 08:09 PM
Sherlock's Avatar
almost as fun as the error I had last week. driving along and BLOOP up on my nav screen comes "dvd error or disc not present".. restart the system, comes up ok for a while.. bloop... disc not present. checked the navi disc door closed, dvd in system.. stupid lemon.. then i found the problem.
ejected the disc, bottom surface was cloudy, wiped it per disc cleaning instructions and problem went away.
problem ?: I had some cleaning wipes in the trunk, the fluid on them evaporated in the trunk air and coated the disc.
Just another one for the books.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Cgannotti
Sep 25, 2015 05:04 PM
rockyboy
Sep 25, 2015 10:44 AM
