Interior lights...what is better?
#81
Single LED??
Anyone have pics of what the car looks like with just a single super white LED installed?? Not really looking to drop 100 bucks in interior lighting....yet :P
#82
maybe I'll take pics later, but I have single super white LED's for all my interiors and it's bright as hell. Take my word for it, you don't need 48924 board LED, single is just fine and isn't over powering or underpowered. Quantity: 6
Product: WLED-xHP High Power LED bulb $ 4.95 (each)
Options: Pure White WLED-WHP
Ok, ill take pics later :p
#85
When pushing in the lens tab be careful not to push too hard or you will bend the tab and it won't hold the lens in place when replaced.
Also it is very helpful to remove the lens from the electrical connector so that when replacing the bulb you don't accidentally cross the metal connectors shorting out the circuit and blow the fuse.
#86
i found an easier way of getting the vanity and trunk open.
i have a gerber pocket multitool. it has a flat head screw driver. it's pretty wide and thin...
i then used a smaller screw driver to pry the plastic cover as i fish for the tab.. i just gently rocked it back and forth and once i hit it, the small screw driver pops it out.
i'll take pictures since i bought the wrong bulb for the trunk
#90
Honda CBR1100XX
i just ordered $142 worth of leds from v-led to complete this mod.
it took me some time to figure out exactly what needed to be replaced. once mine get all in and i get the opportunity to install everything, i can post some photos.
#92
If you mean the exterior side markers, they are already LED. They are replaceable, but unless you go out & buy OEM replacements you need to do some work. 3G Garage has a few DIY threads on replacing them.
If you mean the door courtesy lights, they are 921 wedge type bulbs. You can get the ones that fire straight out, as that is the direction you want the light to go. You want something similar to these:
http://www.v-leds.com/Interior-LED/D...-p4782920.html
#94
thanks for the info dwb993, and i'm referring to the exterior side markers. also what i wanted to know if i was to buy some bulbs from v-led, what type/size would i need to replace the ones for the exterior side markers?
Last edited by R.L. ina TL; 10-10-2009 at 07:02 PM. Reason: forgot to add person i was thanking
#95
Check the 3G Garage---there is a thread there about changing the LEDs in the side markers. I believe he used an LED module from oznium.com. Another guy used switchbacks for his, so they glow white and blink amber---cool stuff and its all in the Garage.
08_UA7_Gr33k
02-11-2016 02:17 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
