Installing amps without loc???
ok so ive been a talking to my installer and he was telling me that it is better to connect the aftermarket amps from the stock headunit from the wires that go before the factory amp......i bought the stinger loc but hes telling me that there is no use for it ......but ive been searchin thru the forums and havent found any details about this type of instalation......
Any opinions about this install is welcome....
You can do that, however the muting for the navigation system won't work properly (only if you have Navi). If you can live with that, go pre-amp! Make sure your amplifier has LOW LEVEL INPUTS.
Do you have experience with this yourself? I took my front signal pre-amp and the HFL and navi cut off sound when appropriate. Maybe it is a radio model thing? I have a 1TB0.
I just came back from the installer and right now hes having a problem with the stinger loc ... at high volumes hes getting a distortion so thats why he proposed to me about that method.....but im not to sure about it
The factory amp is sitting in a box in my garage. I'm running the center off of two bridged channels from a DC360.4 driven by the HU's center output.
I have just experimented with this. I have the stock amp and was getting distortion with the LOC so i figured let me just get rid of it and see what happens. I tapped the signal RCA cable right next to the stock sub so this happened post amp. Because of this, I now have the gains all the way down on my Alpine MRP-M500 but the awesome thing is that now i have full control to the sub from my factory, non navi, headunit.
04 w/ Navi Amp Removed from Car no Issues with HFL or Navi Voice, with sub control from factory HU. Any device that you add to the signal will add distortion.
Head Unit -->Lo Level--> Amp factory--> Hi Level--> Stinger LOC -->Lo Level--> Amp after market --> Hi level --> Speaker
vs.
Head Unit -->Lo Level--> Amp after market --> Hi Level--> Speaker
Less to go wrong, less to buy, less distortion, simpler install.
Just my .02 cents
vs.
Just my .02 cents
vs.
Just my .02 cents
vs.
Just my .02 cents
Posts 27 and 29 in this thread should give you what you are looking for:
https://acurazine.com/forums/showthr...wiring+diagram
AndrewS
19
03-14-2024 06:59 PM
Pegon95
09-15-2015 01:54 PM
alan_rich
09-07-2015 11:08 PM
