Infinity speakers..
Old Aug 24, 2008 | 01:37 PM
Chyeaaaa's Avatar
Infinity speakers..
Ive noticed alot of people on here have gone with the polk audio and have gotten great sound.. Ive been doing some research and what i want to get done is get the most sound out of the stock radio without having to add an amp for the highs... IMO, i think the infinity 2 ohm coaxial speaker along with the 1011t tweet in the front would give the most sound.. What do you guys think??
Link to speaker
http://www.onlinecarstereo.com/CarAu...roductID=15357
Link to tweeter
http://www.onlinecarstereo.com/CarAu...roductID=15364
I also plan on adding a subwoofer and amplifier... If i get enough sound out of the highs, id run 2 12's, if not id probably stick to 1 12..
Old Aug 24, 2008 | 02:48 PM
Trew's Avatar
You're gonna have to amp those infinitys if you want good sound, especially if you're putting a 12" sub in the rear. it will drown out every other sound in the car.
Old Aug 24, 2008 | 02:54 PM
Chyeaaaa's Avatar
But i think it will sound alot better than stock... and possibly substanally better than the polks because these are 2 ohm speakers...
Old Aug 25, 2008 | 12:22 AM
eggyhustles's Avatar
go with a component set..
http://www.onlinecarstereo.com/CarAu...roductID=17540
or even...
http://www.woofersetc.com/index.cfm?...roduct_ID=3059
amp..
http://www.woofersetc.com/index.cfm?...roduct_ID=5479
either or would be a nice budget setup
Old Aug 25, 2008 | 09:30 AM
Chyeaaaa's Avatar
Link to speaker
Link to tweeter
Originally Posted by eggyhustles
So it looks like either way im gonna have to install an amplifier to get the sound i need
Old Aug 25, 2008 | 11:44 AM
TeknoKing's Avatar
^ 100% without a good mono amp for sub and a seperate 4 channel amp for interior speakers, you will not get the sound that you want..there will never be enough juice.
Old Aug 25, 2008 | 05:58 PM
you gotta pay to play..also would be good to sound deaden the doors to get that extra midbass
Old Aug 26, 2008 | 09:11 PM
Chyeaaaa's Avatar
I want to go that route... but if i do, what are the chances that i can keep all my control(HFL, Bluetooth) and still not hear engine noise??
The engine noise would piss me off very much.. mehhhhh
Old Aug 27, 2008 | 06:46 PM
Hpdrifter's Avatar
I too am looking at the polk/ infinity speakers.......Here's what I know about speakers.....Everyone's ear is different. A pair of $1000.00 speakers might not sound as good to you as a pair costing $200.00. Buy the ones that sound better to you......that being said I can't find anywhere that has both, for a side by side. BTW are you comparing the infinity 2 way or 3 way to the Polk?
Old Aug 27, 2008 | 11:18 PM
Chyeaaaa's Avatar
Just the 2 ways.. but still adding a tweeting in line up front
Old Aug 28, 2008 | 10:36 AM
well you are keeping the stock headunit so i don't see why it wouldn't work..to add subs i think you need a hi-low converter..not too sure..i'm sure someone else can chime in
Old Aug 28, 2008 | 10:46 AM
geniusadam69's Avatar
I've installed custom sound systems before, but how do you hook subs into the stock head unit... is there an RCA output on it?
Old Aug 28, 2008 | 05:07 PM
Trew's Avatar
the stock sub has its very own channel. It has a factory harness that it connects to the factory sub. In order to feed a signal to an amp for a sub upgrade, you will need to cut the factory harness and install a Line Output Converter or a Line Output Driver to tone down the output from the stock signal so it can go into an amp. These LOCs will also convert speaker wire to RCA so you can simply connect to an amp input.
tonio
Feb 5, 2019 05:43 PM
TLDude876
Dec 28, 2016 03:18 PM
sockr1
Oct 1, 2015 01:31 AM
pistacio
Sep 26, 2015 09:45 AM
