Incorrect Navi code?
Old Nov 23, 2014 | 07:19 PM
con5tant's Avatar
My battery has been draining and such, so today after I jump started my car I get the navigation code prompt. When I entered the correct code it says "incorrect pin" even though I know it is correct. Radio code works fine. :help:
Old Nov 24, 2014 | 02:41 AM
Will Y.'s Avatar
Registered but harmless
Did you enter the Navi code using the Navi touchscreen?
The Navi code is separate from the radio code, and does not use the radio preset buttons for entry.
Old Nov 24, 2014 | 11:03 AM
con5tant's Avatar
Yes, it's a 4 digit code
Old Nov 24, 2014 | 08:11 PM
Will Y.'s Avatar
OK, try pulling the Navi fuse (#20 ACC, I think) or disconnecting the battery for 45 minutes. Then reconnect and see if the Navi accepts the code.
Otherwise, you may have to check the code number with a dealer by using the VIN and the serial # on the DVD drive.
Jamus22
Jun 11, 2023 10:08 AM
lanechanger
Oct 13, 2015 10:56 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Cgannotti
Sep 25, 2015 05:04 PM
