Incoming calls through V710 Bluetooth
Old Sep 23, 2004 | 11:20 PM
veeru's Avatar
5th Gear
Hi,
Yesterday i got Motorola V710 phone (Verizon wireless) which i thought would work with my new TL. I could able to set up easily and also could able to make calls successfully.
But I could not able to receive the incoming call information (ring).
When i activate the bluetooth in the phone, and if i receive any calls ,the phone is not ringing(but on the phone screen i can see the incoming call info) and at the same time i am not getting any incoming call display(or any sound) in MID.
Can any one faced this problem. Is there any solution for this.
thanks
Veeru
Old Sep 24, 2004 | 08:15 PM
boltjames's Avatar
Team Camel Executive VP
Originally Posted by veeru
Hi,
thanks
Veeru
Yes! Here is the fix:
Change the ringtone. Only about half of the ringtones actually trigger the TL's incoming call function.
Go in the TL and start the engine. Using the 710's menu buttons, navigate to change your ringtone and you'll notice that as you change ringtones (the 710 will play the ringtone....give it a second before you skip to the next one) and you'll hear the TL speak "you have an incoming call" as you change to the ones that work. Pick one that works (obviously) and you're all set.
BJ
Old Sep 24, 2004 | 09:01 PM
tommyt37's Avatar
to boltjames
I just read that whole closed infinity/Tl thread... you are an entertaining guy. I had a good laugh here at work on break(a long one). To bad it was closed I woulda jumped in on that one for sure. Peole gotta relax and have a laugh..as long as there's no name calling and over use of swearing what's the big deal?
To many up tight people around here..
I tried to PM you but it's full
tt
Old Sep 25, 2004 | 09:47 AM
veeru's Avatar
5th Gear
BJ
thanks BJ
MetalGearTypeS
Aug 29, 2016 08:28 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
thegipper
Sep 28, 2015 01:01 PM
