i pod interface question
i need help from anyone who can please.
purchased an i pod interface from gromm . tried to install in my 2004 acura tl. do not have navigation. looks like the white plug they provide to connect interface plugs into the xm radio slot. i plugged it in and got nothing, do i need to purchase the y-connector they advertise, or will this just not work for my car.
it says to use the port for the external cd changer, but i dont think i have one.
any one with pics of the back of the radio??
Best of luck with the install and figuring out the issue here.
thanks for you help- i did have it plugged into the xm radio slot,was able to gain access by removing left side center console cover, and the fact i have small hands.
i tried pushing the xm button & the mode button on radio and nothing.
maybe i got a bad unit. i have e-mailed mfg. sounds like i did have it plugged into the correct slot.
Try pressing the CD buttin twice. That should take you to the CD changer mode, which is what most of these devices use. You will need the Y connector is you want to continue using XM, assuming it works like every other device I have researched.
Hope this helps....
Hope this helps....
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
