How to Wire LED Strips
Old Feb 16, 2009 | 03:41 PM
toe222's Avatar
i need some help figuring out how to wire led strips in the footwells so that they only come on when the doors open. at first i thought it would be as easy as wiring them into the interior fuse.....turns out this does not work. after doing some research i learned that when the doors are closed the circuit is broken (via the ground wire). so apparently i can tap into any 12v power source but i need to find the ground that goes to the doors. i read the install directions for the illuminated footwells so i know it can be done, but he was tapping the ground at the bottom the pillar with seatbelts. anyone know where it is located closer to the fuse panel?
Old Feb 16, 2009 | 06:25 PM
csmeance's Avatar
what year TL do you have?
Old Feb 17, 2009 | 09:28 AM
toe222's Avatar
2005. any help you can give would be great....although i might be taking her into the dealer for a 60k checkup and to take car of those recalls....so maybe they would be willing to tell me.
Old Feb 17, 2009 | 09:31 PM
csmeance's Avatar
def. go for the recalls, an engine fire can start unless they are performed there is no such think as a 60K tune up, at 60K this is what needs to be done:
Change Engine Filter - easy 4 screws (DIY posted here)
Change Cabin Filter - easy, 3-4 screws and some clips (DIY Posted)
Oil Change
Oil Filter Change
Tire rotation
Check brakes
Replace brake fluid if the car is 3 years old and it has not been changed, and if it has been changed, 1 year from fluid change date.
Old Feb 18, 2009 | 09:49 AM
allykahn's Avatar
Interested in wiring as well.
Old Feb 18, 2009 | 09:50 AM
toe222's Avatar
well i am not taking it in for a "scheduled service", but like i said i want those recalls done and also the engine has started making a noise that needs to be fixed, the passenger door handle had a piece break and fall off, the drivers side widow makes a terribly loud noise when i roll it down, and it needs an oil change....so while there might as well get them to look over everything. i just got 4 new tires, oil filter, and wiper blades.
thanks for all the help and advice.....
Old Feb 18, 2009 | 09:54 AM
toe222's Avatar
Well the best thing I have found on wiring was on the install for the illuminated door sills.....so when i get back to town next week i guess that what i am going to try.
i just ordered the blue led for the doors and waiting on them to arrive. how do they look? also i noticed you have dice/dom coming soon. how soo? how do you plan on using it....ipod or dvd? i want to do the same and use it with my video ipod.
Old Feb 19, 2009 | 01:12 AM
Rob RiL's Avatar
Unregistered User
I assume wiring it directly to the driver door light (interior panel of driver door) with positive and negative spliced a few inches before the bulb would work. Or no?
08KBP_VA
Oct 22, 2019 01:55 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
4drviper
Sep 23, 2015 07:42 PM
eastcoastguy
Sep 23, 2015 06:29 AM
