How to stream music from phone?
Old Oct 16, 2011 | 01:29 AM
libert69's Avatar
18psi
04 non nav TL here. Audio noob as well. I know we cant stream music from our phones using bluetooth. I have a htc inspire phone. Im getting tired of using the tape deck with a 3.5mm cable coming from the tape deck into my phone.
Is there any way to connect a 3.5mm cable directly to the backside of the headunit? Will this give better audio quality then using the tape deck? Id like to run the wire under the center console and through the cup holder to eliminate the wire hanging over the shifter.
Old Oct 16, 2011 | 02:33 AM
libert69's Avatar
18psi
Is this my best option? I never use an ipod and I will never own an Iphone. I just want a head phone jack that I can connect my phone to.
It says its plug n play. Once installed, what source must be used on the headunit in order for this to work?
http://www.ebay.com/itm/FACTORY-RADI...item5d2e429043
Old Oct 16, 2011 | 02:52 AM
dwb993's Avatar
Not a bad solution. I have this on my 06. You use the DVD button to select it up as a CD-C (changer). Unfortunately, these units are known to be flaky with Honda head units. Every so often, mine will display "CD4" and play what I'm inputting (CarPC). Disconnecting the battery for a bit resets it.
I am frustrated with it, so I am installing a PIE X3, which gives me 2 additional inputs, should I need/want them.
Old Oct 16, 2011 | 03:04 AM
libert69's Avatar
18psi
Ive been without my car for about 6 months b.c its in florida getting all the motor work done so I honestly forgot what the radio display/buttons look like lol. I dont have navi. What dvd button are you referring to?
from what I remember, there are 3 source buttons I think? disc/tape, am/fm and xm?
Old Oct 16, 2011 | 03:29 AM
libert69's Avatar
18psi
It seems many people are having issues with the blitzsafe unit. iSimple looks less problematic?
http://www.ebay.com/itm/ACURA-IPHONE...item53e695d19e
Compatibility Requirement
- Vehicles equipped with an external 6-disc changer, it must be disconnected for the Interface to function properly.You will lose the use of your factory CD Changer.
- Vehicles equipped with factory satellite tuner, it must be disconnected for the Interface to function properly. You will lose the use of your factory satellite tuner.
Would I lose both the xm and cd options or pick which one I dont want to use anymore?
Old Oct 16, 2011 | 03:48 AM
dwb993's Avatar
iSimple is for iPhones/iPods. You said you would never own one of those.
PIE X3 connects PnP (like Blitzsafe) and adds 3 inputs. There are other solutions----hit the 3G Garage Audio section.
Old Oct 16, 2011 | 03:52 AM
libert69's Avatar
18psi
^from what I understand, there are 2 versions of iSimple. The ebay link I gave is the version that uses rca cables to 3.5mm jack.
"The PXAUX directly connects your Audio Media Device Player to your factory radio through the supplied AUX cable (RCA Audi/3.5mm head phone jack. This universal device can provide audio inputs into your factory radio for devices such as: MP3 players, portable DVD players, laptops, gaming systems"
Both the isimple and blitzsafe are about the same price. Im still trying to figure out if your lose both the cd and xm functions using the isimple.
Old Oct 16, 2011 | 07:48 AM
devildon's Avatar
the isimple usually includes 2 conncetors. it comes with the main gateway that you plug at the head unit, then a cable for ipod, then a second cable that has a standard headphone jack coupled with 2 rca connectors. the isimple shows an ipod input, then aux 1 and aux 2 once its plugged in and accessed through the xm button. i would reccomend the isimple. hope this helps.
Old Oct 17, 2011 | 02:02 PM
libert69's Avatar
18psi
Looks like the product for me is the isimple dualink. It has 2, 3.5mm/rca cables instead of 1 3.5mm/rca cable and 1 ipod cable. Plus, its only 80$ shipped for the dualink which is cheaper then the other model which comes with the ipod cable
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
navtool.com
Sep 25, 2015 05:15 PM
