How long does the battery last with the audio on but the engine off?
30 mins will drop the voltage to keep the car from starting, 20 mins is at the edge...
I think my battery is going bad. I had the radio playing for about 15 minutes on very low volume and the car would no longer start. =( Luckily my friend had jumper cables else I would have been screwed.
is this true? When I was 16 in HS (95-96), I had a 83 Volvo 240DL stationwagon and I would drive to school super early to get a good parking spot and listen to the radio for at least 30 mins. every morning no problem. Either cars have way more electronics sucking juice for no reason or cars aren't built the same as they used to. You would think car batteries have improved over time as well.
all work and no play
you have to keep in mind that the TL system has an amplifier which will suck the power down much faster than a normal radio playing with the engine off would reguardless of volume youre playing it at
though I wouldnt be too suprised if youre battery was in fact weak, the batteries arent exactly known for being dependable
Kahuna, batteries have in fact improved...its a matter of people not wanting to spend the kind of money that a quality battery will cost ........around $200
Jokerman
i have gone hours before playing the radio on the battery alone and was able to start it, also that was after i upgraded my battery. I have done this a bunch of times, but none of them unpurposely.
If yours is dying this fast then you definately need to look at a replacement battery, I have an amp and sub in my TL and I have played it at 28-30 for well over 1 hour and it started without hesitation, I also have systems in my Hummer and Z06 and those both will play for well over 1 hour (I have ran the Hummer for nearly 2 hours but that has a big battery) and they both start without problems.
I would think a factory TL (without additional amps) should be able to play for multiple hours without problems.
Being an Acha Bacha in
20 mts sounds right. I am afraid to run the shit while pumping gas, thas how paranoid I am. Last thing I want is to look sexy and dead at the same time. And if you go get the battery tested, it will come back in spec meaning no change needed. Stock Acura batteries just suck. And dont think its just Acura, my 2006 GS is the same garbage. However it has a more powerful "stock" system.
For those people with upgraded batteries, does this significantly improve the power? I like to run my music while working on the car, always end up needing a jumpstart.
Turd Polisher
Wow, my TL can go for at least 2 hours at a pretty decent volume (10 / 12).
My car was able to start no problem
PS My battery is roughly 2 years old and it's nothing fancy.
For those saying mine can run 2 or 3 hours, think about what you are saying:
1. First of all, its the SUCKY AC DELCO ACURA battery.
2. TL has an amplified that sucks about 200+ WATTS
3. TL has complicated eletronics that run in the background with the radio on, drawing a bit of electric
I have a 2004 TL, my battery was replaced in early 2007, which is pretty good for an acura battery. I got a new one for 10 bux from the dealer due to proration as the battery is warrantied for 2 years full and the 3rd on proration. I'll stick with 10 dollar car batteries rather than dishing out 200 dollars.
I've taken trips from Dallas to Houston on the stock battery where I'll stop off at a rest stop and take a nap for an hour to 2 hours (if I haven't slept the night before). I'll leave my radio on XM during this nap. Never had problems with starting.
As my stock battery got worse and worse, it went dead super quick. Literally 5 minutes or less with the bass amp off and just the stock stereo running. Now with the Optima I can run it for at least 15 min (never tried more) with two aftermarket amps running and it starts just fine.
King of NYC
As said, the Acura's radio sucks more juice than most. It all depends on the volume and equipment. If you are talking about blasting it with a stock ELS I'd say 20min. If you keep the volume very very low you can keep it on for 1 hr. Your battery will recharge as you start and drive awhile so no problems. But the overwhelming question is why would you really want to do this??
I have a 1000watt amp driving 2 subs and lights galore so I have to be even more careful. (My lights dim if I turn it up for even 30 sec...) Even as careful as I am I am on my 3rd battery. My car always starts slow if the car has been sitting more than 5 days. I should be getting an Optima and alternator upgrade actually.
I'm running stock in my 08, and I def know that it's shit battery... I can see it struggling on every other start up... I'm going to go back Yellow Optima I ran in 2G... Those deep cycles batteries went thru abuse in my 2G with over 500RMS (3x10" eclipse w/ avic-z1 and 4 sets of components speakers) pumping for hours with the engine off.
Anyone's running Yellow Optima? Size? Thanks.
Got It
D35 (8040-218) YellowTop®; Deep Cycle Battery; Grp. D35; Cold Crank Amps 650; Crank Amps 810; Reserve Capacity 98; Amp Hour 48; Top Terminal; L-9 5/16 in.; W-6 3/4 in.; H-7 5/8 in.;
corner
corner
Hmm, rockyfeller, D35 fits without a problem???
King of NYC
I believe so, it's classically been the recommended size for Accord/Camrys for awhile. (I used to sell batteries back in the day.) I think it might my very slightly narrower and taller though. The battery cover will probably not fit anymore. Well than damn thing won't fit unless you buy the EXACT OEM battery anyways.
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
darksky
09-05-2015 03:11 AM
