How good is my amp?
How good is my amp?
I didn't want thread jack, so I decided to make my own. I am at a crossroad right one deciding a new sub. The amp I have currently powering the the previous sub is a JL Audio JX 360.2. The two subs I'm trying to decide on is the IDQ 12v3 D4 or get another JL Audio W3v3. So my question is would 360 rms be enough to much the IDQ sub?? Leaning more towards a SQ set up nowadays. There is not a ID dealer in my area for me to even compare the two.
I listen to pretty much all types of music, but mostly hip hop and r&b. I'm not into the hearing my car from blocks away, but still want that bass inside the car be felt and be loud. I read a sealed box out of the recommend size will be a nice balance of bass and SQ or a ported for more bass
The rest of my system is:
ID CXSv2 components in the front
powered by JL Audio J2 320.4 (bridged)
AudioControl Matrix
AudioControl Matrix
That should be plenty of power for the ID sub as long as you go with just one , 2 subs it might not be enough.
Im very pleased with my w3v3 sub , whats making you change ?
AudioControl Matrix
AudioControl Matrix
I too am deciding between these two subs, would love to know what others have to say..
I am also pleased with the way my w3v3 performed, though I may try the SQ route.
I planned on getting one sub
Either sub will do fine on the amp . Im sure if you messed with the settings on your amp you could achieve a good sq from a w3 . Ive been messing with mine but im using a mono channel amp so i have some different settings than a 2 channel amp would have .
Mem04TL (10-11-2012)
That's enough to get loud. I've heard good things about the amps. If they really are the successor to the E and A series, they're solid.
Keep in mind, if you add a second sub with half the power going to each sub, it will be 3db louder. The main benefit is less excursion for a given level with two subs, keeping distortion down.
I was in the same position as you on sealed or ported . I went with a ported setup and couldnt be happier . I think it sounds a bit better than sealed but also depends on how much room you are willing to give up as ported boxes are generally bigger
http://knowledge.sonicelectronix.com...woofer-wiring/
![](http://i102.photobucket.com/albums/m111/mphil21/1_sub_DVC_2_ohm_2ch_bridged.jpg)
If you can give up the space, ported for sure whether its for sq or spl.
Memo - Yes , you are correct . You will need a dual 2 ohm sub and wire it in series to make it a 4 ohm load .
I Hate - Yea my box for my sub is twice the size of a sealed box . But I went with a single sub and still didnt give up to much trunk space . I went with a JL Audio HO110RG-W3v3 and it slams for a single 10" sub ! More than pleased with my decision.
Mem04TL (10-20-2012)
I wonder if I should just get a 10' sub. Isnt more cone space better?
AndrewS
19
03-14-2024 06:59 PM
mada51589
05-03-2022 08:54 PM
Pegon95
09-15-2015 01:54 PM
