How do you get the PIN for navigation after battery died ?
Hey guys, how are all of you doing ? So my 07 Acura TL Type-S' battery died yesterday all of a sudden. When I jump started it, the navigation screen asks me for a 4-digit PIN after the Acura starting screen. I have checked the manual and I see a Anti-Theft Identification Card. I entered the 4 digit navi code but it say incorrect pin, it is that pin, it is even correspond to my VIN number. I am not sure should I go to dealer and let them rip me off, so do you guys have any alternate suggestions ? Much thanks !
I don't see any hard drive unit in the trunk besides the DVD player. Where does it located ? Is it on the top where the lights are just like the TSX ?
Katie (11-20-2023)
Registered but harmless
Received 1,149 Likes
The Navi code can only be entered using the numbers on the touch screen after the Navi disc loads.
If no numbers show on the Navi screen, go to the trunk to eject and reload the Navi DVD.
If that doesn't work, get the serial number off the drive and call Acura.
The radio code is entered with the radio preset buttons below the Navi screen.
G/L, and welcome to AZ.
BANNED
^that...only worked for my radio code.
i had to call the dealership where the car was previously serviced to get the navi code.
I contacted my local dealer & they wanted $150 to give me the codes. I looked in the owners manual & it showed the original selling dealer. I called the service dept. & the called me back in 10 minutes with both the audio & nav codes. Originally they are given to the customer on a card to keep private & supposedly deter people stealing the audio & nav systems.
I disconnected the battery and dumped the codes for the Nav and the radio. Called local dealer and he was able to walk me through the radio code. At the time, I didn't realize I needed the Nav code also. Decided to write the radio code down somewhere I could find it again (that being in the owners manual) and found the radio and Nav code already written in by either the previous owner or one of the service technicians. Thanks to whomever. Might be worth a look through paper work with car.
I recently had to re-enter the navi code as my battery drained a few weeks ago. All the Acura books that came with the car (and had the codes written in them) went missing, there were no tags on the glovebox, and I didn't want to access the DVD player to physically get it as you have to remove some carpeting. I got the navi code by following this link https://radio-navicode.acura.com/. To get the Navi serial number, make sure your navi screen is at the enter code screen, then press and hold down the map/guide + menu + cancel buttons. This brings up the Navi service menu and the serial number for the navi unit is under "Navi ECU". Write down the serial # and use the link to enter it in, along with the VIN. It gave me two codes and one of them worked for the Navi. I hope the other is for my radio unit which I didn't need for the time being.
Aaron Barnes (01-09-2021)
Latent car nut
I called Acura and worked with a representative to get my code.
3rd Gear
I installed a Pioneer head unit and bought the full custom harness from Mobile Max Audio. Needless to say I got the factory navi working again but I couldn't find the navi code which is different than the radio code, I learned. I pulled the carpeting up in the trunk, got the serial from the DVD player, entered it here, and was told it wasn't right. I followed the instructions above and I got the serial in 60 seconds and unlocked the navi. It's so nice to have a backup camera now. Visibility is a nightmare.
Latent car nut
Really? Hmmm, hadn't noticed. I have a 2006 TL which has no backup camera capabilities at all and even though I need to back up into tricky spots all of the time, I've never wished my car had such a backup camera (my wife's car has it and while occasionally handy, I consider it more of a novelty than anything else).
3rd Gear
3rd Gear
MightyTL
02-22-2010 04:23 PM
Anubus12
08-09-2006 03:41 PM
