How To Disconnect Horn?
I was wondering where the horn for the 05 Acura TL is located? How would I go about getting to it in order to temporarily disconnect it? Pictures would be awesome but simple instructions will do just fine. Thanks!
Fuse #13 is for the brake lights and the horn relay. So you can pull that. Or you can pull the horn relay (I think it's in socket A). Open the under-hood fuse/relay box and look on the sticker. You should be able to figure out which one is the horn relay. This is the easiest way.
The horns are under the passengers side head light. Just above the window washer fluid tank. Pop a couple of the clips for the tire well cover and reach back in there. There are two horns on the same bracket.
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
scionxb3003
Sep 14, 2015 01:52 AM
