How To change Rear Speakers???HELP!!!!
Old May 8, 2007 | 01:18 AM
Madvillian's Avatar
3rd Gear
Exclamation How To change Rear Speakers???HELP!!!!
My rear right speaker has been blown and I need to change it out but I could not get into the speaker compartment..I attempted to go in from the trunk but there is a metal tray that protects all three speakers..Do I need to remove the back seats or something of that nature to get to the speakers..I don't want to go to a professional installation place for such a minor speaker switch...Please help me with any suggestions on how to get to the rear speakers so i can change them out..
Old May 8, 2007 | 04:47 AM
TLFourplay's Avatar
Remove rear seats, bottom and back, remove rear deck. Just basically pull it off. Than you can directly access the speakers. Make sure you check the ohms on your replacement speaker, they are 2 ohms so it would be difficult to find aftermarket speakers, better off going with an acura replacement.
Old May 8, 2007 | 10:17 PM
Kracker's Avatar
05 TL
I had no problems replacing every speaker in my car.... Except the sub. FYI you will also have to sides off.. C pillars? But the suckest part is the seat back.. I hate them.
The speakers I got were Infinity 62.7i Car Audio 6 1/2" ($82.95 pair) from hifisoundconnection .com
This thread is replacing the center channel and tweeters:
https://acurazine.com/forums/showthr...6&page=1&pp=25
You have to make your own hole for the rears:
https://acurazine.com/forums/showpos...1&postcount=99
Fronts: ($82.95 pair)
https://acurazine.com/forums/showpos...6&postcount=97
And this thread tells you the sizes and the specs for the speakers.
https://acurazine.com/forums/showthread.php?t=89837
Old May 9, 2007 | 03:02 AM
datmrman's Avatar
Thanks Kracker.
Welcome aboard Madvillian. Please perform a search before posting.
There are several threads on speaker/amp replacement. Many are outlined in the 3G Garage and the 3G TL Audio & Electronics FAQ.
Good luck!
Old May 10, 2007 | 12:46 AM
Madvillian's Avatar
3rd Gear
Thanx fellas.I will try to remove the back seat,then tray..Hopefully I won't rip anything up trying to do the switch out.I will keep you posted
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Aleax
Sep 11, 2015 11:31 AM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
