Hissing sound when accelerating and using HFL
Old Jan 17, 2017 | 02:21 PM
mazen222's Avatar
I finally replaced my defective HFL module and now it works fine, except that i hear a light hissing/frequency noise in the background which increases with the cars RPM...
Any ideas?
Old Jan 17, 2017 | 02:25 PM
if you turn off the volume to radio, does it still happen? Usually that's the alternator, the amp, or a bad ground somewhere.
Old Jan 19, 2017 | 08:34 AM
alexb92's Avatar
Look up TSB B07-013 on this page: https://acurazine.com/forums/third-g...-016-a-613659/
You will have to follow the instructions at the top to open the PDF on how to fix this.
Old Jan 19, 2017 | 12:13 PM
mazen222's Avatar
The sound does go away when i put the volume to zero.
I will check out the TSB.
I know i need to fix my amp because i get a similar but louder noise when my car is cold
Old Jan 19, 2017 | 12:18 PM
mazen222's Avatar
After reading this, it looks like that is exactly my problem! Thanks!
Old Jan 19, 2017 | 12:22 PM
Sounds like the amp is on its way out to me !
Old Jan 19, 2017 | 07:50 PM
WDPanda's Avatar
You have a grounding loop issue. If your amp was on it's way out it would have already. You need to see an electrician but first look at all 3 ground points on your engine bay and consider the alternator as this sounds like alternator whine.
Old Jan 20, 2017 | 10:22 AM
mazen222's Avatar
Why not just apply the SB? It exactly describes my problem...
My amp does have issues as well, as I get a loud hissing when the car is cold and goes away when it warms up. I saw a post about replacing the capacitors on it that seems would fix it. So i just have to get myself to do it some day.
I sure hope its not my alternator!
Old Jan 20, 2017 | 10:25 PM
alexb92's Avatar
Follow the service bulletin for now.
My amp has made a hissing sound forever when its cold out, and usually it's pretty much gone after a minute. No need to panic.
