HFL Skip the confirmation?
Old Jul 15, 2007 | 09:22 AM
hoc_james's Avatar
I've got a bunch of names stores in the HFL phonebook. Whenever I ask the car to dial an entry it asks me if I want to dial the entry. Is there any way to disable this confirmation and just have the entry dialed?
Old Jul 15, 2007 | 10:02 AM
crzygosu87's Avatar
Down for a photoshoot?
That might not always be a good thing to have ... in cases in which perhaps there's a little too much ambient noise in your car, the system might not clearly pick up the name and can dial the wrong person, then you'll initiate the annoying "one ringer" as I like to call it when the other person on the line hears his/her phone ring exactly once, then that person checks his or her phone and calls back via caller ID, which in turn gets in the way of the ACTUAL call you're trying to make, then you get confused as to who you're actually speaking to because certainly you just dialed the right person on your second try, but it seems to be someone else's voice ... and all of this while you're driving ... hhaaahaha I'm just exaggerating ... there might be a way to get around this, but I think even though it is a bit of a hassle, it's a bit necessary to double check who you're calling since you're using voice command ... I remember sometimes my car picks up an entirely random name that has absolutely no resemblance to the name I was intending to call @___@ faulty systems those can be sometimes
Old Jul 15, 2007 | 11:00 AM
hoc_james's Avatar
yeah that's true, but I'm hoping Acura left that decision up to me. Honestly, the HFL very rarely gets it wrong and when it does it is usually because I'm driving with the windows down. Also, I've noticed a slight lag between when the HFL shows the number in the MID and when the phone actually places the call and it's more than sufficient time for me to verify the number visually and end the call before the phone places the call.
Old Jul 15, 2007 | 01:22 PM
Will Y.'s Avatar
Registered but harmless
Push down the HFL "on" button and hold it down as soon as the full number shows in the MID-- you can release the HFL button when it starts to dial.
And welcome to Acurazine.
Old Jul 15, 2007 | 03:35 PM
hoc_james's Avatar
Thank-you. And thank-you.
4drviper
Apr 23, 2025 07:13 PM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
Jimmy_D
Oct 7, 2015 11:52 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
