Help - trying to wire JL Cleansweep
Old Jul 20, 2011 | 04:36 PM
aimmaster's Avatar
like the title says, i need help wiring this damn thing... i have wired the speakers harness already but need help wiring the power connection harness.
anyone know exactly what wires the go to... i have an 06 TL non-navi
if anyone could please tell me what wires connect with what i would greatly appreciate it...
i need to connect these 4 wires:
the amp fuse-
the ground-
ignition/accessory-
remote out to amplifier-
Old Jul 20, 2011 | 07:38 PM
DiamondJoeQuimby's Avatar
Codename Duchess
1) honestly, if that part of the install is troubling you, I'd stop and take it to a professional, or at least find a buddy that really knows what they are doing. Not a "yeah, i install stuff here and there" kinda buddy.
2) In the interest of being helpful, ground it to chassis metal...aka a ground, 12v and switched 12v can be had at the amp, the radio the fuse box or ignition harness.
3) The cleansweep is really not needed in the TL if you grab signal before the factory amp. All the DSP is in the amp so the only reason you'd need a cleansweep is if you went after...which in this car doesn't make sense. The only thing a cleansweep will really do for you is give you a line driver (you could use an Audio Control Matrix for cheaper) and or an aux in which can be done w/ a USA Spec or iSimple.
Old Jul 20, 2011 | 07:50 PM
aimmaster's Avatar
i know the simplistic part of it but ive seen three different schematics of the wiring... i have the wiring diagram of the speakers only but im missing the other pages. this is why i ask.
i also got the cleansweep for 50 bucks off some guy that didnt even get to install it in his car.
i also went earlier to a shop to see how much it would cost just to wire this and he was trying to charge 65 for 1 hour when i know this job could be done in no more that 20 min if that.
Old Jul 21, 2011 | 01:57 PM
jda123's Avatar
Dogmatic Dinosaur
Take it out - you just don't need it.
If you must use it, you can use an add-a-fuse on #32 for accessory. You can also tap into the stock amp remote wire.
Old Jul 21, 2011 | 09:27 PM
Codename Duchess
The Cleansweep cannot be reliably installed in 20 min. Sorry it just can't. It will take 20 min to properly remove the back seat to run wires to the trunk.
And it doesn't matter what you paid, it is still not needed in this car. And I am a huge JL nutswinger.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
