Help request for 07 Type S Auxillary Jack Schematic
Hello everyone. I need help on identifying the 5 pins of the Auxillary Jack for 07 Type S TL. I got the jack but I don't know what harness to get. worst case scenario, I'll have to solder the connection of these 5 pins. Does any one have the pin schematics of the auxillary jack? The auxillary jack goes in the rear console storage box along with the secondary 12V jack. Thanx for your help.
Originally Posted by rbf351
5 pin connector (same harness used old honda/acura cruise control harness)
Pin 1 - Aux detection
Pin 2 - ground
Pin 3 - Signal ground
Pin 4 - Left signal
Pin 5 - Right signal
Pin 2 - ground
Pin 4 - Left signal
Originally Posted by psheu
Kool...
thanx for the tip... but which one is pin 1?
if looking into the harness(pin side) it would be on the left (release tab on top)
normally it would be on the right if you are looking at the part(release needs to be on top)
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
