Help power wire signal
I need a car in
I'm wiring up a relay to power up all my in car entertainment parts. I was wondering is there a place I can tap to in the trunk for the signal ie. When the ignition is on that wire get power. Thanks
I ran a power line from the under dash fusebox to the trunk to power my NavTool. Fuse #32 is the ACC fuse. I used an Add-A-Fuse and it has been working fine for almost 6 months now. No need to remove the back seat, either.
Another option would be to run a lower gauge (thicker) line directly from the battery to the trunk, depending on how many devices you need to power. Kits are available from stereo shops to do this.
I tapped into an empty fuse slot for ignition on the relay and just ran one thin cable to the back to power on my equipment.
that might be the best bet
You can try the ignition line on the fuel pump but, im not sure if thats recommended.
I need a car in
alright thanks. ill just run a fuse line all the way to the trunk and run it all they way back up front. im running a 5ga wire from the bat to the trunk for all my power need switch by the relay.
I need a car in
also i was wondering is there a reverse signal up in front of the car? or would i be best tapping into the reverse light signal from the reverse lights?
run along side the 5ga wire another smaller sized one. Like the ones for remote turn on lead.
I taped them together every 1ft. Makes it easier to run.
By the fuse panel you use one of the open ones with a fuse tap for your ignition turn on.
Do know how to wire the relay all up?
Jul 16, 2017 07:33 AM
navtool.com
31
Nov 16, 2015 08:30 PM
SUPRMN84
Oct 7, 2015 09:46 PM
