Help--LED DRL lights dim with 1000 watt amp
Old Jul 17, 2014 | 04:34 PM
tdub206's Avatar
I have a 2008 tl with a 1000watt apline pdx 1.1000 pushing a JLw7-12. I noticed the led drl dim a little when the volume is turnt up and the speaker is kicking.
Im using good 4ga power and ground wire not that cheap stuff. Im using the factory radio so i tap into the factory sub with the line out converter. I scratched off the paint where i grounded. I've searched around here and i seen someone say 1000watt is enough for the tl to handle. So my question is do i have to change out my alternator to something with more amps or do i just have to change out the big3. Or should i not even have any problems at all and its just my conncections.
Old Jul 17, 2014 | 04:39 PM
the_tl_man09's Avatar
i have an 06 tl and im running 2100 watts and the only thing that dims are the interior light (the ones you click on an off)
Old Jul 17, 2014 | 05:51 PM
tdub206's Avatar
So does that mean my alternator is going bad? I checked the voltage by the amp on the power and ground lead and there is a drop in voltage when the speaker knocks at high volume maybe to the low 12s.
Old Jul 18, 2014 | 10:19 AM
350's Avatar
350
My first ricer
Maybe use a harness so the DRLs get their power right from the battery? Big 3 is really easy on this car, I did a grounding star around the engine to both fenders and a larger negative battery terminal. I don't have LED DRL's but nothing dims with an 800 watt amp.
mada51589
Jan 9, 2025 04:40 PM
sockr1
Oct 1, 2015 01:31 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
JnC
Sep 11, 2015 06:06 AM
Fadij
Sep 2, 2015 08:31 PM
