HELP! Which iPod setup???
Old Mar 7, 2009 | 08:00 AM
Deep 3.2TL's Avatar
Exclamation HELP! Which iPod setup???
Hi All,
I know this has probably been asked a million times, but I couldn't find a thread that brought it all together.
Situation - I have received an iPod Touch as a gift for my birthday. I'd like to integrate it into the TL. I have a 2006 TL with Navi. I do NOT have XM and as a result have no SAT or XM button. There is no Aux in on the car (that I can see anyways, unless I'm missing something).
I've seen a bunch of different integration kits out there, but if I could get opinions on the best for my situation that would be great!!
I'd be awesome to have it all on screen, but I don't think that's possible without having the XM/SAT button, right?
Help!!
Thanks,
Deep
Old Mar 7, 2009 | 08:20 AM
Trew's Avatar
Are you in Canada?
If I'm not mistaken, although the car is not equipped with XM, there is still a connection in the back of the radio. You can still connect an iPod integration harness to the back of the radio.
The iSimple from Peripheral Electronics does a great job of integrating iPods to our stereo systems. It allows for radio and steering wheel controls to operate your iPod.
This seems to be the most popular solution, and is what I bought as well. Check this thread for a Group Buy.
https://acurazine.com/forums/sponsored-sales-group-buys-10/isimple-group-buy-707785/
Old Mar 7, 2009 | 10:43 AM
Deep 3.2TL's Avatar
Hi Trew - Yes, I'm in Canada.
From what I've read on crutchfield for example, if you have Nav, the iSimple doesn't work. It says not compatible with your car (I guess cuz of the Navi?)
Also - it will not charge the Touch 2nd gen (which I have)
I'll check out that link however!
Old Mar 7, 2009 | 12:41 PM
ladiesman217's Avatar
e92 335i
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/ipod-text-display-selection-706831/
Old Mar 7, 2009 | 10:09 PM
Trew's Avatar
That's an incorrect statement. It fits fine. I have NAVI and I installed mine today. It connects and works perfectly. I bought it from Uncald4. You can PM him if you want more info.
Trust me, it will work with NAVI even though it says it won't. Ask anyone here with NAVI and an iSimple and they will tell you.
Old Mar 7, 2009 | 10:27 PM
Deep 3.2TL's Avatar
Ok - good to know.
How was the install? How long did it take you? connect from behind the radio?
Also - Do you need to remove power to the radio while doing this? I don't have the radio code, so might be an issue if you do...
Old Mar 7, 2009 | 10:31 PM
acura911's Avatar
you need to have xm in the car for the pxamg to work.you don't have to pay for the xm you just need the button for it to work you hook it up to the xm port in the back of the radio.
Old Mar 7, 2009 | 10:32 PM
Trew's Avatar
It wasn't bad. Took me maybe 30 minutes with help.
You'll have to remove the driver side trim piece and knee panel, which will require removal of the lower dash cover on the driver's side. Doing this will make things much easier for you - the trim piece pops right off and there are about 6 screws to remove to get the panels off.
Old Mar 7, 2009 | 11:37 PM
Deep 3.2TL's Avatar
acura911 - This is why I'm hestitant in joining the group buy unless there has been a canadian on it. I don't believe XM was standard or even available equipment in Canada in this year. I do NOT have an XM button so the iSimple will not work?
Old Mar 8, 2009 | 01:10 PM
Trew's Avatar
Sorry, I didn't know the Canadian models did not have an XM button. Agree, if you don't have the XM button, I don't think the iSimple will work.
There is a member here with the username "Peripheral". He works for Peripheral Electrionics - who makes the iSimple. Send him a PM and ask him to get the official answer.
Old Mar 8, 2009 | 08:17 PM
Deep 3.2TL's Avatar
uncald4 said that he's researched it himself and it won't work for a Canadian model...
Oh well!!!
Old Mar 9, 2009 | 01:34 PM
Fred99x's Avatar
06 WDP TL Owner
The 06 Canadian head unit does not have the XM button or even list XM as an option but the head unit does allow XM. On my 06 TL, with the NEO ipod adapter, I just have to press the mode button on the steering wheel to scroll through the various inputs. The adapter simulates XM and thus by using the mode button, you can access the XM feature, it even indicates XM in the TL display. Since I don't have the iSimple I cannot verify if this will work on the Canadian TL but contact the vendor for verification.
Old Mar 10, 2009 | 05:09 PM
Deep 3.2TL's Avatar
Any Canadians reading this - I've found the USA Spec units PA15HON2 in Canada locally (Oakville) for $149 CAD. That's a great price considering exchange, shipping, brokerage, etc.
Old Mar 10, 2009 | 05:31 PM
ttribe's Avatar
Here you go - everything you need to know for installation (this one is for the USA Spec, but the steps are essentially the same for all): https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-160-usa-spec-install-633080/
Old Mar 11, 2009 | 09:17 PM
Deep 3.2TL's Avatar
Thanks for that link - I was going to post today looking for a DIY on it. I wish there were pics of where he placed the knife to take off the trim and what comes off in what order...
Old Mar 12, 2009 | 12:00 PM
ttribe's Avatar
Regarding the silver trim - Start from the back (near the arm rest) and you'll find spaces where you can twist the knife and the next closest clip will pop. Keep doing that until you get up near the nav screen. There are three clips up there that are difficult. Most people start getting rather nervous at this point (including me) that they are going to break something or bend the trim (since most of it is loose). You just need to apply a little extra "tug" on the trim (holding it near the clips that are still in place) and it will come loose. Best of luck.
Old Mar 12, 2009 | 01:50 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
iSimple is the way to go if you don't care too much about video being displayed. If you want video depending on what APPLE device you have you need to a little more research.
Old Mar 12, 2009 | 11:05 PM
Deep 3.2TL's Avatar
iSimple is too expensive... $210 CAD on the group buy with the 3g cable and shipping. Picked up the PA15HON2 USA Spec for $149 locally.
Old Mar 19, 2009 | 02:14 PM
meagain's Avatar
Does anyone know WHY iSimple states it won't work with Nav units?
Old Mar 22, 2009 | 04:45 AM
ef9jeff's Avatar
Is it even possible to purchase a 07 US head unit for us canadians and install it seeing in how the 07 plays mp3's and wma's???
If im going to fork out money for a new unit, why not spend the extra lil bit for the option of mp3 cds....
other that that... all one needs to do technically is purchase an xm button equipped unit and plug their regular ipod adaptor in and wham your good as gold?
Old Mar 23, 2009 | 04:27 PM
ttribe's Avatar
I guess I'm not entirely sure what you are asking with this...I don't seen any reason why you couldn't purchase the 07 version of the head unit...it's just a part like any other...but it will be expensive.
Additionally, I don't know why the focus on the XM button...you don't have to have an XM button to get some of these iPod adapters to work. For example, I use the USA Spec HON2Y and I can get to it by using the "Disc/Tape" button since the head unit recognizes the adapter as a second CD-Changer.
Old Mar 24, 2009 | 01:25 AM
Tote's Avatar
A different version of the OP's question:
I have an Iphone 3g & 07 Type-S with XM NavTraffic (not subscribed yet but will be in a couple months) so as I understand it the ISimple won't work.
I don't really care to have video capability through the Navi but I would like text display and control through the steering wheel and Iphone. Also want to maintain integration with HFL though it seems that most solutions provide this.
Can anyone recommend a solution for this? I've been reading the forums but my head is swimming in all the different components and model year/accessory compatibilites and I don't have time to search anymore.
Thanks in advance.
Old Mar 25, 2009 | 09:37 AM
Deep 3.2TL's Avatar
Thanks in advance.
The upcoming USA Spec PA15-HON3 will allow for your install. Supports 3G phones, will allow XM Traffic to stay in tact.
Not available yet, another month or so according to USA Spec
Old Mar 25, 2009 | 11:20 AM
uncald4's Avatar
Former Sponsor
The Peripheral PGHHD2 harness is an active SKU currently. Just waiting for stock. The PGHHD2 harness for the iSimple allows NavTraffic.
Old Mar 25, 2009 | 11:33 AM
Tote's Avatar
Thanks Deep3.2 & uncald4. I'll do some research on those units and let you know what I decide.
Old Mar 25, 2009 | 11:41 AM
TLinVA's Avatar
Hi uncald4, I'm looking to connect a Sirius plug-n-play directly into a NavTraffic enabled head unit and have also been told about the upcoming PGHHD2 from Peripheral. Do you know which port on the back of the radio will this use and/or which button it will use on the head unit?
Thanks!
Old Mar 25, 2009 | 12:59 PM
uncald4's Avatar
Former Sponsor
Thanks!
Word.
Your XM source button will access anything connected to the Peripheral PXAMG. The PGHHD2 cable will most likely be similar to the PGHHD1 and plug into the expansion plug on the rear of the TL radio where your XM is currently plugged in. Although, I have not seen the PGHHD2 cable yet.
Old Mar 25, 2009 | 01:38 PM
stephen.parker's Avatar
No, that ↓ is not me...
Lightbulb
Our stereos play DVD-A (DVD-audio) format and you can download this guide: http://tloftulsa.com/dvda/ which was written up by rimz who is a member here. I've used the Adobinizer and it works great!
Sorry op, not trying to hijack your thread...
Old May 27, 2009 | 04:32 PM
Hi Deep, if you don't mind, can you tell me where you picked up your PA15-HON2 for $149? I can't PM cause I don't have enough posts.
Thanks man!
ps. Sorry for bumping this thread!
Old May 30, 2009 | 10:43 PM
Deep 3.2TL's Avatar
Audio Illusions in Oakville.
http://www.audioillusion.ca/
Old Jul 7, 2009 | 04:04 PM
nabeelj's Avatar
I called them, they quoted me C$220.
Old Jul 9, 2009 | 03:12 AM
Deep 3.2TL's Avatar
Strange - call back and say that you know someone that got it for $149. I have the invoice still, I'd be happy to scan it and send it if it helps...
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
TLguy42
Sep 26, 2015 11:27 AM
dirleton
Sep 25, 2015 12:25 AM
