Help installing Subs in 2006 TL
Old Mar 24, 2014 | 11:12 PM
GRaffStewart's Avatar
8th Gear
Hey guys, just bought my TL last week and I'm looking to putting in my 2 12" subs in the trunk. I have the navi system. Are there RCA inputs somewhere behind the navi or radio that i can run my RCA cables from my amp/sub to the factory stereo? If not what would be the best way to hook up the subs to the radio? Splicing from the current subs would bypass my amp, and the current stock amp in the TL is no where near powerful enough to make the subs go boom.
any options?
thanks
Old Mar 25, 2014 | 12:50 AM
RxWorld's Avatar
You take the speaker wire that connects to the stock sub and use a hi lo converter to turn that into an RCA output which you connect to your aftermarket amp. It retains sub controls on your aftermarket amp using the stock headunit
Old Mar 25, 2014 | 10:46 AM
Vlad_Type_S's Avatar
Registered Bike Offender
This thread has everything you need. The converter you need is called an LOC (Line Output Converter). http://www.crutchfield.com/S-MRp9eP0...onverters.html
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/%24200-subwoofer-project-install-instructions-pics-904119/
Old Mar 25, 2014 | 11:38 PM
8th Gear
yeah i used one of those before i got my new head unit on my old 99 Toyota Solara. Totoally forgot about that, thanks guys
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
