Help Installing LED Scanner
Old Aug 15, 2008 | 10:27 PM
dlphnsjk's Avatar
i saw one in another tl-s and i thought it looked pretty cool and i wanted to do the mod. i purchased a varad led scanner. im not good at all with electrical stuff and i wanted to know if anyone could assist me on what wires i connect and where those wires are in my car.
http://www.ragingspeed.co.uk/catalog...r_Scanners.htm
thats the type i bought.
Old Aug 16, 2008 | 12:22 AM
csmeance's Avatar
is this just a light that serves the purpose of showing you have an alarm? Though I think it's somewhat cheesy, but I would think you need to wire it into a constant power with a relay that connects to the cig lighter so when the car is on, it doesn't blink, but when the car is off it will blink.
Old Aug 16, 2008 | 02:56 AM
VmtSquad's Avatar
"Advance"
....I dont understand that one
Old Aug 17, 2008 | 01:20 PM
dlphnsjk's Avatar
can you be more specifc?
Old Aug 17, 2008 | 09:24 PM
Keepitclean's Avatar
It's been some years since I've wired one of those Varad scanners on an old
Pontiac Grand Prix I used to own....
But, if I remember correctly, the scanner had three wires that needed to be connected:
1. A wire with a constant power source (can easily be found in the fuse box or directly to the positive side of battery.)
2. The ignition wire. You'll need to tap/splice into that. (I know it was a pink wire under the steering column of many GM cars. You'll need to find out which wire it is for your specific make, model and year.)
3. The ground (negative) wire.
The Varad scanner would be activated/on only when the ignition/car is off. When the car is started and running, the scanner would be "off".
(Your Varad scanner should have come with installation instructions)
Old Aug 17, 2008 | 09:42 PM
csmeance's Avatar
for the ignition wire, tap the cig lighters fuse, and for the constant, the radio fuse should work.
Old Aug 17, 2008 | 10:18 PM
dlphnsjk's Avatar
thanks all, i will try to post some pics once i install it, still awaiting it in the mail.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Iakonafuji
Sep 21, 2015 02:39 PM
Greengecko
Sep 16, 2015 08:19 PM
ghuns
Sep 16, 2015 04:26 PM
