HELP!!! Amp and line driver won't power on...
Old Jun 11, 2012 | 09:20 PM
Seatown1two's Avatar
I'm using an add a fuse for #32, ground bolt that deathtotoasters used, double checked fuse at battery, and shortened ground to ~1ft... I'm at a loss.. pls help I got 2 hrs b4 it gets dark!!!!
Old Jun 11, 2012 | 09:24 PM
djtsmith007's Avatar
ElectroMechanicalEngineer
Got a meter to check connections? And where they working to begin with?
Old Jun 11, 2012 | 09:26 PM
Just completed install with connections to amp 2nd to last and fuse at battery being the very last thing I did... No meter.....
Old Jun 11, 2012 | 10:05 PM
Trunk Monkey's Avatar
Coolest A-zine Member
If you unplugged the neg from the battery...did you plug it back up? Simple, but ya never know. Are you sure your add a fuse is good?
Old Jun 11, 2012 | 10:48 PM
pohljm's Avatar
A multi meter is invaluable in troubleshooting this issue if all wiring and fuses look to be good.
Old Jun 11, 2012 | 11:54 PM
Soooo simple... I knew my power and ground wires were both live because when I put the fuse in there was a small spark. Same with the ground, touched it to my grounding spot and another small spark. So it all came down to the remote wire. Had originally pulled the fuse out of #32 and plugged it into add a fuse then plugged it in. After trying a couple different things (which consisted of smoking several cigs and reading up online) I decided the only other thing that makes sense that I was missing was to put a 2nd fuse on the add a fuse. WWOW I'M A RETARD.... Finally I got power!!!
Write up of install w/ pics soon to come... Too exhausted...
Old Jun 12, 2012 | 01:06 AM
stevemk07's Avatar
Thumbs down
Glad you figured it out.
Old Jun 12, 2012 | 07:29 AM
Boom. I'm good.
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
sockr1
Oct 1, 2015 01:31 AM
Sep 14, 2015 03:16 PM
