HELP!! amp install... question!!
Old Oct 2, 2009 | 11:00 AM
lenjaiah's Avatar
could someone point me to the right place to wire up the power wire for the amp... (the wire that turns on the amp) thanks..
Old Oct 2, 2009 | 11:33 AM
lenjaiah's Avatar
i know to any accessory wire when the car is turn on but WHERE???
pictures or diagrams would be helpful...
sorry if this has been ask a million times.. i search and still searching... please help!!
Old Oct 2, 2009 | 01:15 PM
VmtSquad's Avatar
"Advance"
In a "normal" setup and this is the most common way. You got 3 wires going to the amp and then you got the wires going from the amp to the sub or speakers.
1- Remote; this small wire tells the amp to turn ON when car is up, so the best way IMO to do this is to route a wire from the fuse box under the hood (usually have a free spot).
2- Power; this wire is usually a high gage wire that runs from the battery to the 12+ connector on the AMP. This wire gives power to your amp and sub.
3- RCA; You need to route the sound from the stereo to the amp (right -left)
Hope this helps!
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
