help with alarm wiring
Old Jul 17, 2009 | 05:56 PM
cbass's Avatar
i just got an alarm and im trying to avoid buying a module. im gonna install it myself and im just wondering if anyone can help from experience in finding the door trigger and unlock/lock wires.
thanks
Old Jul 17, 2009 | 06:00 PM
KaMLuNg's Avatar
have you even done an alarm install before??? i would step away from the vehicle if you haven't... this ain't no HU install...
WIRING INFORMATION - ACURA / TL / 2006 / Remote Start
[PRINT THIS PAGE]
12volts white (50A) + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/red + ignition harness
Second Accessory white/red + ignition harness
Keysense red/white - ignition harness
Power Lock pink/black - green plug, left side of fuse box
Notes: These wires will meter when using the passenger door lock switch.
Power Unlock pink/blue - green plug, left side of fuse box
Lock Motor yellow/black 5wi green plug, front of fuse box
Unlock Motor yellow/green 5wi green plug, front of fuse box
Parking Lights+ red/black + large white plug, top of fuse box
Parking Lights- red/black - headlight switch in column cover
Hazards green/red + large white plug, top of fuse box
Turn Signal(L) red/blue + large white plug, top of fuse box
Turn Signal(R) white + large white plug, top of fuse box
Reverse Light green + driver kick, harness to rear
Door Trigger see notes - rear of fuse box
Notes: The LF door is green in a 16 pin plug, pin 15. The RF door is lt. green/red in a 14 pin plug, pin 12. The LR door is green/yellow in a 16 pin plug, pin 14. The RR door is green/white in a 14 pin plug, pin 13. Use all four wires and diode isolate each.
Dome Supervision green/red - green 5 pin plug, rear of fuse box
Trunk/Hatch Pin blue/yellow - green plug, left side of fuse box
Hood Pin yellow/red or green/black - hood pin switch in latch
Trunk/Hatch Release yellow/green or blue/black + driver kick, harness to rear
Power Sliding Door N/A
Factory Alarm Arm blue/white to white/red - driver door module in door
Factory Alarm Disarm black/red to white - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer NOT yellow/black ac any fuel injector
Wait to start N/A
Brake Wire white/black + brake pedal switch
Parking Brake green/orange - large white plug, top of fuse box
Horn Trigger green/yellow - horn switch
Memory Seat 1 blue/yellow - driver door module in door
Memory Seat 2 red/yellow - driver door module in door
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models. When using the 556HW, follow the mode 1 wiring diagram. The reference wire is brown/yellow, data wire is red/blue and ignition wire is black/green.
Old Jul 17, 2009 | 08:34 PM
CSWBiggs's Avatar
y in the world would you avoid buying the module?
-Jason
Old Jul 17, 2009 | 08:43 PM
cbass's Avatar
yea i work at a store actually car audio/alarm place. just trying to save some money instead of gettin module..
Old Jul 17, 2009 | 08:46 PM
cbass's Avatar
[PRINT THIS PAGE]
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Wait to start N/A
Memory Seat 3 N/A -
Yes Type:
Transponder
Part #: 556HW
yea this is from 12volt right? i got that sheet already just havent found all of the wires yet
Old Jul 17, 2009 | 10:49 PM
CSWBiggs's Avatar
WIRE COLOR POLARITY LOCATION
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/WHITE (-) IN HARNESS AT PASSENGER SIDE FUSE BOX BEHIND DASH
Domelight Super BLACK/WHITE (-) IN HARNESS AT PASSENGER SIDE FUSE BOX BEHIND DASH
LF Latch GREEN (-) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #E15
RF Latch LIGHT GREEN/RED (-) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #H12
LR Latch GREEN/YELLOW (-) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #E14
RR Latch GREEN/WHITE (-) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #H13
Trunk Trigger BLUE/YELLOW (-) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #P24
Hood Trigger YELLOW/SILVER DOTS (-) IN HARNESS AT PASSENGER SIDE FUSE BOX BEHIND DASH
Alarm Disarm BLUE (-) AT KEY CYLINDER IN DRIVERS DOOR
Parking Lights RED/BLACK (+) IGNITION SWITCH HARNESS
Convenience
Headlights-Lo BLUE/RED (+) AT VEHICLE LIGHT SWITCH HARNESS
Wipers-Lo BLUE (-) AT VEHICLE WIPER SWITCH HARNESS
Wipers-Hi BLUE/YELLOW (-) AT VEHICLE WIPER SWITCH HARNESS
Trnk Release BLUE/BLACK (+) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #F5
Remote Start
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense RED/WHITE (-) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #P13
Tachometer BLUE/SILVER DOTS (AC) IN PLUG ON DRIVERS SIDE SHOCK TOWER UNDER HOOD
Speed Sense BLUE/WHITE (AC) IN HARNESS AT REAR OF GAUGES
Brake Lights WHITE/BLACK (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights GREEN/BLACK (+) IN HARNESS IN DRIVERS DOOR SILL
Horn GREEN/LIGHT BLUE (-) IGNITION SWITCH HARNESS
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock PINK/BLUE (-) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #P9
PowerLock PINK/BLACK (-) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #P25
2 Step Unlock YELLOW/BLACK (+) AT KEYLESS ENTRY MODULE IN DRIVERS KICKPANEL
PIN #K12 THIS WILL UNLOCK THE DRIVERS DOOR ONLY.
Driver Mtr Unlock WHITE/RED (REV) AT MOTOR IN DOOR
Driver Mtr Lock YELLOW (REV) AT MOTOR IN DOOR
Pas Mtr Unlock RED/YELLOW (REV) AT MOTOR IN DOOR
Pas Mtr Lock LIGHT GREEN/RED (REV) AT MOTOR IN DOOR
LF Window Up RED/YELLOW (REV) AT MOTOR IN DOOR
LF Window Dn RED/BLUE (REV) AT MOTOR IN DOOR
RF Window Up BLUE/WHITE (REV) AT MOTOR IN DOOR
RF Window Dn BLUE/YELLOW (REV) AT MOTOR IN DOOR
LR Window Up RED/BLUE (REV) AT MOTOR IN DOOR
LR Window Dn RED/YELLOW (REV) AT MOTOR IN DOOR
RR Window Up RED/BLACK (REV) AT MOTOR IN DOOR
RR Window Dn RED/YELLOW (REV) AT MOTOR IN DOOR
Sunroof Open GREEN/YELLOW (REV) AT VEHICLE SUNROOF SWITCH
Sunroof Close GREEN/RED (REV) AT VEHICLE SUNROOF SWITCH
-rookie...would help if you specified a year and trim of vehicle..
-Jason
Old Jul 17, 2009 | 11:42 PM
cbass's Avatar
a regular 2004 Acura tl. thanks
Old Jul 17, 2009 | 11:52 PM
CSWBiggs's Avatar
if there's any difference..
All Door Trigger BLACK/WHITE (-) 4 PIN CONECTOR PASS FUSE PANEL
PIN #E15
PIN #H12
PIN #E14
PIN #H13
Trunk Trigger ORANGE/SILVER DOTS (-) 18 PIN CONN GRAY PLUG ABOVE DRIVERS KICK PANEL
OR BLU/GREEN (-) DRIVERS FUSE BOX
Hood Trigger YELLOW/SILVER DOTS (-) 24 PIN BLUE CONN PASS SIDE FUSE BOX
Alarm Disarm BLUE (-) DRIVERS DOOR CYLINDER NO UNLOCK
Alarm Arm BLUE (-) MODULE LOCATED IN PASSENGER DOOR PANEL
Parking Lights RED/BLACK (+) 10 PIN PLUG RIGHT SIDE OF COLUMN OR (PASS KICK)
Low Crr Pk Lights RED/YELLOW (-) LEFT OF THE STEERING COLUMN
Convenience
Headlights-Lo BLUE/RED (-) HARNESS FROM LIGHT SWITCH
Wipers-Lo BLUE (-) LEFT OF THE STEERING COLUMN
Wipers-Hi BLUE/YELLOW (-) LEFT OF THE STEERING COLUMN
Parking Brake GREEN/WHITE (-) HAND BRAKE LEVER
Trnk Release WHITE/SILVER DOTS (-) 6 PIN GREEN PLUG ON FUSEPANEL
WHITE/RED AT MUX MODULE
Remote Start
Anti-Theft Type TRANSPONDER
Anti-Theft Descript AN RF SIGNAL ACTIVATED SYSTEM
Key Sense BLUE/WHITE (-) IGNITION SWITCH HARNESS
PIN #P13
Neutral Safety GRAY (-) IN HARNESS TO TRANSMISSION
Tachometer BLUE/SIVER DOTS (AC) 2 PIN PLUG ON DRIVERS DOOR SHOCK TOWER
Speed Sense BLUE/WHITE (AC) PIN 2 OF 14 PIN CONNECTOR REAR OF CLUSTER
Low Crr. Pk Lights RED/YELLOW (-) LEFT OF THE STEERING COLUMN
Brake Lights WJITE/BLACK (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights GREEN/BLACK (+) IN HARNESS IN DRIVERS KICKPANEL
Horn GREEN/LIGHT BLUE (-) AT STEERING COLUMN
Modules
WIRE LOCATION
Module 1 MUX - LOCATED BEHIND GLOVE BOX
Doorlocks/Windows
Power Unlock PINK/BLUE (-) 20 PIN PLUG PASS FUSE PANEL
PIN #P9
PowerLock PINK/BLACK (-) 20 PIN PLUG PASS FUSE PANEL
PIN #P25
Driver Mtr Unlock YELLOW (REV) DRIVERS FUSE BOX AT GREEN 18 PIN CONN.
Driver Mtr Lock WHITE/RED (REV) DRIVERS FUSE BOX AT GREEN 18 PIN CONN.
Pas Mtr Unlock LIGHT GREEN/RED (REV) AT MUX MODULE
Pas Mtr Lock RED/YELLOW (REV) AT MOTOR IN DOOR
LF Window Up RED/YELLOW (REV) DRIVERS DOOR CONTROLLER MODULE
LF Window Dn RED/BLUE (REV) DRIVERS DOOR CONTROLLER MODULE
RF Window Up BLUE/WHITE (REV) PASSDOOR CONTROLLER MODULE
RF Window Dn BLUE/YELLOW (REV) PASSDOOR CONTROLLER MODULE
LR Window Up RED/BLUE (REV) DRIVERS REAR DOOR CONTROLLER MODULE
LR Window Dn RED/YELLOW (REV) DRIVERS REAR DOOR CONTROLLER MODULE
RR Window Up RED/BLACK (REV) PASS REAR DOOR CONTROLLER MODULE
RR Window Dn RED/YELLOW (REV) PASS REAR DOOR CONTROLLER MODULE
Sunroof Open YELLOWB OR (GREEN.YELLOW (REV) SUN ROOF RELAY ABOVE DRIVERS KICK
Sunroof Close RED OR (GREEN/RED) (REV) SUN ROOF RELAY ABOVE DRIVERS KICK
best of luck
-Jason
Old Jul 18, 2009 | 12:10 AM
cbass's Avatar
thanks! i'll attempt to find the wires again tomorrow. the first time i looked i was told there was a passenger side fuse box..
Old Jul 18, 2009 | 12:11 AM
nfnsquared's Avatar
If you're to cheap to buy a module, you'll have to waste your time access the door trigger wires in the driver's side door panel and then routing them back into the car through the door wire tunnels. It's a PITA. Believe me, it's worth the money just to buy the module.
If you don't believe, just PM PeterUbers. He'll tell you the same thing.
Old Jul 18, 2009 | 12:53 AM
cbass's Avatar
so is there a passenger side fuse box?
Old Jul 18, 2009 | 12:55 AM
Maddizm's Avatar
Seriously? You're gonna waste so much time if you don't buy the module (I'm assuming Bypass Kit) THat will make your life so much easier. Just get it and you just have to wire the alarm into the bypass kit, and you'll have doors, trunk, and the factory alarm will still arm!
Old Jul 18, 2009 | 01:16 AM
cbass's Avatar
well i figured if i can find the wire some where near a fuse box it wouldnt be hard to wire up, but if its that hard i guess the module is the way to go
Jul 16, 2017 07:33 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
