Help!!
Help!!
Long story short, I had to replaced my battery after only 4 months after i bought the car , It is an 04 but i was told they had replaced the battery and i didn't had to worry (Carmax). Well i know this is not normal, the battery should last about 2 to 3 years, so should i be worry? i hope this doesn't happen again in 4 months. can an ipod charger be the problem?
To make things worse, The radio is asking for a Code, i did some search and i found that by pressing 1 and 6 i could retrieve the serial number. Can anyone help me get the code with my serial number?
Thanks in advance...
Originally Posted by evanj5
do you have any idea what dealer the car was purchased at. Because you can call the dealer the car was purchased at and they will have the code on file.
Originally Posted by kizzerkiza
This may be a dumb question, but have you looked in the maintenance book? Usually radio/navi codes can be found there.
Originally Posted by Charlie209
...Thats the first place i looked hopping i would find a card or something with a code, but nothing
The codes are on card stock (smaller than the manual) and given to us in the vinyl pouch w/the manuals and warranties-- check every part of the pouch and make sure the card is not stuck inside the other paperwork.
Otherwise, you're stuck giving the serial # to the Acura dealer to get the codes. G/L.
I called carmax a while ago, and they told me to call back on Monday ,
i believe that one or two members work here for acura. In general, acura batteries suck. They last ab out 2 years or 50K, the warranty on the batterys from acura is 3 years so they give you a new battery for free most of the time or if out of warranty, pro-rate a new battery. Like posted above, check in the leather manual pouch for the codes, check the door-jamb on the driver side, check the side of the glove-box, check the top of the glove-box, and also you can go to a dealer with the serial number and they can give you the radio code if you provide proof of ownership for the vehicle. Also check the owner-link page, it might be stored there from the old owner or the dealership.
