Have you replaced your speakers?
05WDP Midlife crisis
Hey folks. Looking for some real time experience. I would like to replace my front speakers, not the center channel. All the installers I have contacted in my area are looking to gut the car, new speakers, new amps, lots of money, etc. I just want to see if someone has located a 2 ohm speaker and installed it, and of course was the sound quality worth the labor. Rather leave the rear stage alone, and the sub, though not booming.....well rather not get into amps etc. Thanks!
Speed Addict
The DVD-A Script Guy
Originally Posted by 2LOW4U
Change the amps first, the stock speakers sound great with an amp on them... ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
So I agree with 2LOW4U but add that you should get amps that are stable with 2ohm loads. Not usually a problem but just make sure. Also, the stock speakers aren't rated for huge wattage (search, lots of other posts on their specs) but you will be OK with going a bit higher than they are rated as long as your power is CLEAN. Remember, low wattage clipped signals do more damage typically than a clean signal at 50% higher or more wattage. If after that you still want new drivers then now you have lots more choices since you will have control over the power going to each. You will have effectively removed the 2ohm and efficiency/sensitivity issues and can then shop for some really good drivers.
AndrewS
19
03-14-2024 06:59 PM
Pegon95
09-15-2015 01:54 PM
